Home > Help Needed / General Tech Chat > Oil pressure reducer
Jordanmercer
Member #: 9716
Edenbridge, Kent
Hi guys just finishing my first engine and putting a oil cooler on is there a reducer bolt or something that my pipe from the oil cooler plugs on to any help would be great thanks
I'm not really sure what you mean, but don't fit an oil cooler unless you really need to, and if you are going to fit one, make sure you fit a thermostat to the oil cooler, overly cold oil doesn't help matters at all.
Jordanmercer
Member #: 9716
Edenbridge, Kent
Ok thanks I thought oil cooler was a must.
Fit an oil temp gauge, if the oil goes over 100 degrees id fit one, other than that wouldn't bother, just something else to make room for in the engine bay if you don't need it!
Jordanmercer
Member #: 9716
Edenbridge, Kent
Ok thanks for the help mate really trying to get it on the road for the summer
no worries!
OEM Metro turbo had a small oil cooler, as did autos, none had a stat.
I'd say in this case a small cooler like that would never do any harm.
