Home > Help Needed / General Tech Chat > metro turbo dizzy
minimenzies
Member #: 10628
Colchester, Essex
I am at the stage where i need to think about ignition now. I have come up wight the standard metro turbo dizzy but the question is with the electronic module what do i do with this do i earth it as I'm not running the metro controller? Do i earth them. I haven't bought one just so its still up for discussion. I am aware with fixing weights and springs in the normal dizzy but wouldn't it be better run the metro item fixed at 7 degrees and work from there.
any help would be good
thanks Nic
Mr Joshua
Member #: 1954
Luton Bedfordshire
You should have two wires both go to the coil
Own the day
