Home > Help Needed / General Tech Chat > Rust converter ,inhibitor treatmant,
so gents, just what is the best ,easiest to use, its just a precautionary thing for the new project car
carl
Callum
Member #: 10396
Stoke-on-Trent
I have only used two types, Kurust which I think it shit, and rustbusters FE 123 which seems very good to me.
Did the best in a 'Practiacal Classics' test aswell.
http://www.rust.co.uk/products/category/28...rust-converter/
I've always used Kurust. I found it best to wire brush the worst off then Kurust the remaining rust, then wire brush again and apply a second coat. Then a coat of zinc primer.
eden7842
Member #: 8852
leicestershire
Built hamber make the best stuff it's called hydrate 80 I believe
Kurust has always done a good job for me.
It's all snake oil! There's only one cure for rust and that is new metal!
Edited by apbellamy on 11th Feb, 2014.
Agreed but krust has slowed stuff down for me in the past, but then I ve never used it on bad areas..
tadge44
Member #: 2500
Buckinghamshire
Bilt Hamber stuff is the best range of stuff I have ever used - and I reckon I have tried most of them over the last 40 years.
Andy is right though, replace the metal, don,t treat the rust whenever possible.
At Astons we only used stuff called Rustroy. No idea where to get it from though
turbochargedstu
Member #: 908
gateshead
jenolite is good too. as used by rolls royce on aero engines.
balls to the blower!!!
Rammie2000
Member #: 10190
belgium
*Clapping**Clapping**Clapping* same idea... my car had been done with stuf like that but didnt really help... result... 4 years later i replaced almost every panel
cheers chaps. bought some hydrate 80, ,its just as a precaution on some light surface rust .
carl
