| Home > Help Needed / General Tech Chat > Megajolt connection | |||||||
11th Feb, 2014 at 10:18:15am
I,m back again with questions on Megajolt - I,m just no good with electronics.
11th Feb, 2014 at 10:22:01am
The lead has a sort of phone plug at both ends, then that pulgs into a sort of adaptor for the laptop.
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
11th Feb, 2014 at 10:29:32am
Maplins do them I think |
![]() 539 Posts Member #: 6807 Post Whore York |
11th Feb, 2014 at 10:33:25am
It's an RJ11 connector. You need to patch up a lead to suit this to convert it to either a DB9 (parralel) or USB connection depending on if your laptop has the parallel port.
Edited by adcyork on 11th Feb, 2014. |
11th Feb, 2014 at 11:00:37am
Im not the best with computers either. Got all my stuff from trigger wheels. May be a few quid more, but at least you know its all compatible. Also the trigger wheels support is second to none! Any issues they will be happy to talk you through whats going wrong |
62 Posts Member #: 10207 Advanced Member |
11th Feb, 2014 at 11:14:15am
Hehe sell it and buy a NODIZ.. less wiring (No ancient EDIS module), bluetooth for communications, easy :)
11th Feb, 2014 at 01:05:35pm
Thanks everyone -TM comes up with the goods yet again !
11th Feb, 2014 at 02:01:17pm
No probs, when you fancy the upgrade let me know :) |
11th Feb, 2014 at 02:50:59pm
I just made my own rj11 to db9 serial lead in my build thread, it was a faff to solder but I think a neater solution to the adapter supplied to convert the two On 26th Jan, 2012 Tom Fenton said:
11th Feb, 2014 at 04:41:03pm
Looking around I have found a ESB to LAN ethernet connector which looks as if all I need to do is plug that to the RJ11 male to male and then into the laptop - or am I being stupid again ? |
11th Feb, 2014 at 04:48:13pm
I believe you need to go through a usb adaptor. Thats what I had to do on mine... |
11th Feb, 2014 at 04:58:14pm
LAN is an RJ45 connector, same style as an RJ11 but 8 pins wide instead of 6.
Edited by Rod S on 11th Feb, 2014. Schrödinger's cat - so which one am I ??? |
11th Feb, 2014 at 05:30:05pm
Thanks Rod.
11th Feb, 2014 at 05:41:50pm
Double edit...
11th Feb, 2014 at 05:50:09pm
The diagram confused me a little until i had everything in front of me, the db9 in the diagram is the face of the female connector, and the megajolt rj11 is looking at it as if it were in front of you. Could make for some mistakes if you aren't careful and double check On 26th Jan, 2012 Tom Fenton said:
14th Feb, 2014 at 01:32:42pm
I,m back again -sorry
14th Feb, 2014 at 01:49:42pm
On 11th Feb, 2014 mtechmatt said:
No probs, when you fancy the upgrade let me know :) Likewise if you wish to push your products through this forum please see the "Traders" button at the bottom of the page.
15th Feb, 2014 at 07:21:30am
On 14th Feb, 2014 tadge44 said:
I,m back again -sorry I have a DB9 to RJ11 cable and an RS232 as well as a male to male RJ11 The RS232 clearly plugs straight into the laptop. The adapter to RJ 11 plugs male/female DB9 no problem and the other end is a 6 pin RJ11 which fits straight into the MJ unit. I,m pretty good with welder, grinder and spanners but this electickery just does my head in. Will the above work or have I bought the wrong DB9 to RJ11 adapter, despite the help above ? Is it a 6 pin RJ11 on the MJ ??? I thought it would be at first but when I looked at their website it looked like the 4 pin version, hence my editing my post.... Anyway, if it plugs in it should be OK. RJ11 is a strange standard, it actually allows for 2, 4 or 6 pins but often the 6 pin connector gets used but with only the 4 centre wires connected. Will it work ??? Try and see. The main problem that occurs with RS232 is the Tx (transmit) and Rx (receive) wires end up the wrong way around. Tx has to go to Rx and vice versa, sometimes this is dealt with at the connections in the plugs, sometimes the wires are crossed over end to end in the cable. By using a series of bits plugged together there is a 50:50 chance of it being right. If you look up the diagram on their website of how to wire a single cable up you can check your setup end to end with a plain DVM. Or, as I say, just try it. No harm will come if Tx and Rx are reversed, it simply won't "talk". EDIT - typos Edited by Rod S on 15th Feb, 2014. Schrödinger's cat - so which one am I ??? |
15th Feb, 2014 at 08:55:27am
Obliged to you again Rod.
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
15th Feb, 2014 at 09:04:54am
You could always power it up on the bench with a battery and check that you can connect to it.
15th Feb, 2014 at 11:48:48am
Yes lee I know, but I am such an idiot with these things I might knacker it by connecting something wrong! |
15th Feb, 2014 at 12:01:32pm
It's very difficult to do something wrong with RS232 serial cable wiring that will do any harm, well apart from plugging it into the 240V mains perhaps.....
