| Home > Help Needed / General Tech Chat > front mount radiator plumbing :) | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
11th Feb, 2014 at 02:13:54pm
Hello guys,
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
11th Feb, 2014 at 03:20:27pm
Blank it off, thats whats done on mine |
11th Feb, 2014 at 06:33:36pm
Cool what did you do for tye heater matrix On 10th Mar, 2012 theoneeyedlizard said:
11th Feb, 2014 at 08:02:59pm
On my Fiat Rad (not yet installed, I'm still using the Mk1 Metro at the moment) the "third" connection isn't really there.
11th Feb, 2014 at 09:17:32pm
But I can use the sandwich plate to the heater matrix connection on the passenger side and the heater tap on drivers side as normal?
11th Feb, 2014 at 10:14:35pm
Why not go from the bottom hose into the heater and out to head heater tap? |
12th Feb, 2014 at 08:09:18am
On 11th Feb, 2014 Craigie-B said:
But I can use the sandwich plate to the heater matrix connection on the passenger side and the heater tap on drivers side as normal? No, there will be little or no flow through the heater. The sandwich plate (only used on Metros as an alternative to the No 4 head tapping) and the standard Mini head tappping are both on the "hot" side, and pressurised after the pump. You need one "hot" (either No4 head end or sandwich plate) which is pressurised by the pump and one "cold", suction, ie, before the pump. I made up a Tee piece on the main return line from the front mounted radiator just before it went into the pump suction. Schrödinger's cat - so which one am I ??? |
12th Feb, 2014 at 08:16:42am
Ahh that makes sense - thanks guys I think I may have a plan of action :)
Edited by Craigie-B on 12th Feb, 2014. On 10th Mar, 2012 theoneeyedlizard said:
12th Feb, 2014 at 08:45:06am
Here's how I did my heater return
13th Feb, 2014 at 09:52:22pm
Perfect! Thats exactly what I had in my mind - thank you :) On 10th Mar, 2012 theoneeyedlizard said:
