Home > Technical Chat > Plenum capacity
steve w
Member #: 1917
AKA chargedzetec
I'm going to have a go at a side fed plenum as well the itb setup I have on the go.
Done a fair bit of searching, but does anyone have a definitive answer on plenum size?
I've heard 1.5 x capacity mentioned.
Is that the capacity of the plenum it's self, or with the runners aswell?
Is that the minimum size, or optimum?
If I wanted something more universal for future, is it better to lean towards it being bigger?
as I understand it the plenum needs to be a big enough resovoir to fill the cylinder totally, this needs to take into account any ram/pulse effect pushing past 100% VE, i think 1.5 is used as a safe bet that wont be huge.
and the 1.5 is just the plenum, not the runners too.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I made a plenum recently and hunted round for help. There is a lot of conflicting infomation out there. My plenum was for a 750cc engine so at 1.5 capacity this was a tiny plenum and not really ideal. In the end I just made it so the trumpets fitted and it fitted in the space I have available. It ended up about 3.5l, which is quite small in reality when you consider the voulme of air going through it at 10k rpm..
http://www.twin-turbo.co.uk
Daniel
Member #: 720
Gloucestershire
Don't these plenum volume ratios relate to a true "plenum" which is on the intake side of the throttle?
I've also found totally contradicting information on ideal volume, some said 100% of engine says, 2x engine size some 50% of engine size. With all this info I assumed it didn't make much difference so went on what material I had available at the time.
Concentrate more on the shape and the inlet entry. You want to avoid a design that favours airflow to some TBs at the expense of others.
Lots of ideas for this on the net.
Custard
Member #: 8215
Rayleigh
Make two different sizes and do back to back tests!
Dave the Cake
