Home > Help Needed / General Tech Chat > Gearbox 3rd Motion shaft question. A to A+
jonny f
Member #: 9894
Dorking
Hi all,
Hopefully some can help.
I would like to change the 3rd motion shaft in my 4 synchro A box to the A+ type.
Am i right in thinking that all the gears will fit on the shaft and all I will need is a new 1st motion, pinion nut and an 18mm bearing?
thanks
Edited by jonny f on 12th Feb, 2014.
jonny f
Member #: 9894
Dorking
Guess works has confirmed that this is fine to do. Everything will fit.
