| Home > Help Needed / General Tech Chat > Which clutch plate? | |||||||
12th Feb, 2014 at 08:49:09pm
I've been doing a bit of searching but come up with nothing clear.
12th Feb, 2014 at 08:51:51pm
a standard non sprung plate would be enough imo or a few extra quid for the ap rally one to be sure
Yes i moved to the darkside |
12th Feb, 2014 at 08:58:56pm
the ap turbo plates are a fair bit cheaper than the rally plates though... |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
12th Feb, 2014 at 09:02:23pm
Standard are good for around 120 if you read minispares.
12th Feb, 2014 at 09:05:17pm
saw that Lee, however I'm considering the increased clamping pressure of the rts |
12th Feb, 2014 at 09:21:35pm
I'm also running the rts or should I say will be.
12th Feb, 2014 at 10:17:44pm
with mine the stock turbo plate gripped to around 200 lbs ft ,then the ap rally plate gripped above that . so on 150 the stock turbo should be ample . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Feb, 2014 at 10:20:09pm
thanks Robert. I think i'll give it a go. worst case I'll simply change it |
12th Feb, 2014 at 10:23:50pm
yeah eoither the 180mm ap rally plate or the 190mm one, the 190 is cheaper and seems up to the job On 28th Aug, 2011 Kean said:
13th Feb, 2014 at 12:20:16am
just as a comparison. I run a pre verto with ultralight flywheel, machined lightweight backplate and 5 finger paddle clutch.
13th Feb, 2014 at 07:41:10am
Is that just due to the RTS being stiff and not having as much control on the pedal? Possibly a case for an extended arm?
In the 13's at last!.. Just |
13th Feb, 2014 at 09:12:05am
well I've ordered a standard AP turbo plate for now.
13th Feb, 2014 at 10:43:19am
13th Feb, 2014 at 11:53:25am
Joe do you have a link for the extended arm or is it a home brew item.
On 13th Feb, 2014 Joe C said:
worth considering, easy enough to do too. What the mind can conceive the mini can achieve
13th Feb, 2014 at 12:18:10pm
It's home brew lee. Two std arms cut and shut. In the 13's at last!.. Just |
13th Feb, 2014 at 03:33:54pm
13th Feb, 2014 at 04:43:02pm
On 13th Feb, 2014 welshdan said:
just as a comparison. I run a pre verto with ultralight flywheel, machined lightweight backplate and 5 finger paddle clutch. my brother runs an rts (not sure what springs he has used), along with an ap rally friction plate. I moved his car the other day and the clutch in his is heavier and has a more fierce bite than my current setup also running a grey diaphragm on mine. just to add its a nice setup on his, but more vicious than mine! though it does the job, and he is running the std length verto arm. I might consider going rts in the future, now that there are lightweight verto flywheels available. though I am also considering a superlight pre verto flywheel for my current setup so who knows.... |
13th Feb, 2014 at 07:42:06pm
Joe, do you adjust the position of the slave cylinder as well?
make it about 1/3 longer. |
13th Feb, 2014 at 08:30:28pm
yep, pack it up with washers,
13th Feb, 2014 at 08:47:41pm
cheers Joe. I was wondering if the cable arm could be used. think i'll give it a try |
13th Feb, 2014 at 09:11:12pm
the cable arm ios a bit of a faf but is doable,
13th Feb, 2014 at 09:13:55pm
I was thinking I could make up some bushes instead of the bearings |
13th Feb, 2014 at 09:21:54pm
