| Home > Help Needed / General Tech Chat > Modding a HS4 carb as per vizard bible | |||||||
117 Posts Member #: 7308 Advanced Member Devon |
13th Feb, 2014 at 09:01:20am
Hi all,
![]() 293 Posts Member #: 10010 Senior Member Northants |
13th Feb, 2014 at 10:03:43am
Here are a few pictures i have found online that might help, haven't tried it myself so can't comment on the results.
13th Feb, 2014 at 10:31:00am
That does seem to make it a bit clearer, looks like I could be getting some stones and maybe having a play. Any ideas on if the piston is worth rounding off the edge? Edited by masterchief on 13th Feb, 2014. |
13th Feb, 2014 at 03:16:11pm
It was a while ago I found those pictures, but I was under the impression that you shouldn't touch the piston of the bridge at all as it can mess things up, plus at full throttle the piston shouldn't be in the way anyhow.
13th Feb, 2014 at 08:16:52pm
a bit more info
13th Feb, 2014 at 09:49:26pm
You'll need to use carbides to cut the ally, stones will just clog.
