Home > Help Needed / General Tech Chat > o/t audi a3
wng691s clubby
Member #: 9252
Cleethorpes
hi guys im having an issue with the miss audi iv searched what seems to be all the audi forums and cant seem to find an answer but i know some of you guys have or have had them. right well if your driving along say in 3rd and put your foot to the floor the revs increase quickly but no physical acceleration ease off the pedal and revs drop speed increases. car has had a new cluch less than 6months no lights on dash or error codes in vagcom. any ideas as what to look into would be great im looking at the egr and boost hoses today. thanks
Done now needs redoing lol
Revs going up and speed not is 100% clutch related. Maybe a leaking seal contaminating the plate?
wng691s clubby
Member #: 9252
Cleethorpes
this is what i was thinking ringing the garage that installed it today as it has a years guaranty
I'd tend to agree; if the revs are rising, without increase in road speed, its got to be a driveline issue. Are you getting any burning smells from it suggesting the clutch it slipping?
Clutch, forget VAGCOM, get the spanners out instead.
wng691s clubby
Member #: 9252
Cleethorpes
no smells ect that you would expect from a slipping clutch no noise rattles or nocking it had darkside developments dmf and clutch kit fitted when it was done
wng691s clubby
Member #: 9252
Cleethorpes
thanks for the replys guys, il have to delve deeper
I assume these have a hydraulic clutch operations; just wondering if this is failing to back off fully and hold a bit of pressure on the clutch?
dev 11
Member #: 9393
stoke on trent
Get it in the garage who did the clutch bud warranty jobby
evolotion
Member #: 83
Glasgow, Scotland
check the clutch pedal fully releases the master cylinder. this has caught me out on a customers car that had had a new engine fitted (by another garage) I dont know why anyone would want to adjust the pedal but i have seen it happen.
Denis O'Brien.
Tomm
Member #: 1432
Kent
What model A3?
I had a very similar issue on my BAM engined TT same as the S3. Turned out to be a £15 sensor on the clutch pedal.
If it under warranty I would agree with most of the above and just take it back.
