Home > Help Needed / General Tech Chat > pictures of home made plenum
oliver122
Member #: 9625
hey guys , anybody got any pictures of your home made plenums , i thinking of building one as an airbox without the restrictor ring so i can have my air filter at the front of the engine bay to try and reduce induction noise , just an idea i had while sat bored
turbo or n/a?
I would assume NA as is talking about using this to get the airfilter to the front of the car.
oliver122
Member #: 9625
n/a atm while i source parts for a turbo build , i already have a turbo plenum ready for when i do go turbo -
http://www.theminiforum.co.uk/forums/topic...ne-bay-styling/ if you scroll down you will see what i mean
Edited by oliver122 on 26th Feb, 2014.
You don't need a plenum for that purpose. If you have multiple TBs or inlet ports a plenum is needed. Or in the case of the Metro turbo, the plenum is there purely to control fuel pressure.
For what you want you can just run a bit of pipe.
