| Home > General Chat > forged piston advice / valuation. | |||||||
28th Feb, 2014 at 01:56:18pm
Ayup all.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
28th Feb, 2014 at 09:32:09pm
lucky it didn't hit the bore ?
28th Feb, 2014 at 09:38:19pm
i have never heard or seen of this problem ? ............ anyone else ?
614 Posts Member #: 2153 Post Whore kings langley |
1st Mar, 2014 at 09:44:19am
If you had buttons in those the buttons would have been touching the bore by
1st Mar, 2014 at 10:19:07am
Never had a problem with circlips or spring clips coming loose.
1st Mar, 2014 at 10:30:37am
pantsed rods, maybe been heated too much to fit/unfit the pins,
1st Mar, 2014 at 10:50:31am
I noticed when fitting my spring clips, that they can be clipped into place, but if the gudgeon pip isn't fitted in the correct central position then the second spring clip will not fully clip into place. It looked and sounded like it had, but there was a gap behind it. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Mar, 2014 at 12:29:37pm
I think joes on the money tbh. That's not the worst either I was very close to disaster.
1st Mar, 2014 at 12:38:38pm
is there actually anything wrong with them? damaged at all?if not, could you just put some new spring clips in and use them? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Mar, 2014 at 12:53:02pm
Nothing wrong at all matty but there not clip there the heat up type is it pressfit? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
1st Mar, 2014 at 09:22:49pm
Matty, the Accralite pistons are an interference fit pin.
Edited by Sprocket on 1st Mar, 2014. On 26th Oct, 2004 TurboDave16v said:
2nd Mar, 2014 at 03:04:41pm
Thanks sprocket but like I said I've already brought replacements now so I'm set, just after selling really either as is or pistons and rod bolts and il save the rods for future use with bushes in the little ends 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2nd Mar, 2014 at 04:24:17pm
I,d be interested in the pistons only |
2nd Mar, 2014 at 04:54:15pm
After a bit more thought I've decided I'm going to hang on to them for abit. Emergency / future builds.
2nd Mar, 2014 at 08:13:22pm
good decision. |
3rd Mar, 2014 at 01:14:52pm
TBH that looks normal to how mine are, as I can move the piston from side to said and the Pin stick out a little, it's not going past the out side of the piston so isn't a problem. Best 1/4 mile 13.2 seconds @116 mph
3rd Mar, 2014 at 11:59:09pm
On 3rd Mar, 2014 Miniwilliams said:
TBH that looks normal to how mine are, as I can move the piston from side to said and the Pin stick out a little, it's not going past the out side of the piston so isn't a problem. eden check what matt says ................ you may be going down the wrong track ?
4th Mar, 2014 at 08:42:28am
correct me if im wrong
4th Mar, 2014 at 08:52:32am
Pressed in to the rod buddy. Interference fit into them. If something is worth doing, it's worth doing half of. |
4th Mar, 2014 at 09:12:25am
ohh my bad.. haha today i lent that the wrist pin is an interference fit into to con rod yay!
4th Mar, 2014 at 10:00:37am
Il get a picture of the worst one Steve, but they definitely ain't where I left them Edited by eden7842 on 4th Mar, 2014. 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
4th Mar, 2014 at 10:40:59am
Thete ism't that much side clearance on the little end so yes, it's not right. On 26th Oct, 2004 TurboDave16v said:
4th Mar, 2014 at 12:04:22pm
My bore was very lucky
