| Home > Technical Chat > Cam timing nightmare | |||||||
87 Posts Member #: 10069 Advanced Member |
1st Mar, 2014 at 05:20:19pm
Guys totally flumaxed with timing in my KC500 cam...
1st Mar, 2014 at 05:24:21pm
Sorry crank at TDC....not cam |
1st Mar, 2014 at 05:27:30pm
Nevermind I've confused myself, you need to rock the crank using the dti on the piston to find exact tdc, then I can't remember the rest as it's been a while since I last did one! Edited by Carlzilla on 1st Mar, 2014. On 26th Jan, 2012 Tom Fenton said:
1st Mar, 2014 at 05:31:33pm
you turn the engine clockwise looking at the waterpump end,
1st Mar, 2014 at 05:32:12pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4769
1st Mar, 2014 at 07:21:03pm
Hi joe
1st Mar, 2014 at 08:04:10pm
Well the protractor reads 0 through the 360. Cam number two (from the end of the face you are looking at/the first inlet lobe) lobe needs to be at the peak of it's lift and halfway through its dwell, then I would rotate the crank clockwise to reach the desired degrees of timing, if you overshoot it, rotate it back about 1/4 turn and rerotate the crank clockwise again to the desired timing. The reason for this is because I like to play it safe and accounts for slack in the timing chain when checking the timing once/if the chain is on. Edited by Carlzilla on 1st Mar, 2014. On 26th Jan, 2012 Tom Fenton said:
1st Mar, 2014 at 10:59:44pm
Ok for the actual cam timing,
1st Mar, 2014 at 10:59:45pm
2nd Mar, 2014 at 11:02:59am
Basically you do the above because the TDC and max lift areas have a dwell period so are harder to determine accurately by eye
10th Mar, 2014 at 07:20:30pm
Okie kokie.... Think I be got it thanks... Right 5 thou before 90deg and 121deg 5 thou after... So 105.5 would you say......... But... I'm hearing time in at 108 and 110........to time in at...
10th Mar, 2014 at 07:23:04pm
Ooooh and another quickly....which way is the offset key going in to advance the timing(moving the cam gear clock wise) or to retard anticlockwise..... |
10th Mar, 2014 at 07:50:18pm
This is what Kent Cams say...
10th Mar, 2014 at 07:56:14pm
yep, looks like youve got it, 105.5 sounds right.
12th Mar, 2014 at 08:03:41am
All sorted thanks 5deg offset key in...now 110.5 with new chain...thanks again for the support... |
