Home > General Chat > O/T sprocket ratio help
Had a little google time but could not find what i wanted
i have two sprockets linked via chain
I need sprocket A (say 30mm dia) to do one full revolution for sprocket B's half revolution what size will sprocket B be? i would say double size (60mm) but is it really that simple?
Ta
Easier to count teeth *wink*
For example, Large sprocket 24 teeth small sprocket 12 teeth.......obviously tooth profile must be the same otherwise they wont run on the same chain. Number of teeth x pitch will then determine the circumference
Is this for the toylander? Bmx stuff (if of any use) is around 2.7:1 (mine is 25 to 9) but mountain bike singular rear cogs might work for you, they are used to convert geared rear hubs to single speed with spacers. They are quite small too, http://2.bp.blogspot.com/-T4Gb5KJ58So/T8kZ...00/DSC_0246.jpg
lee.pb
Member #: 9199
Lancashire
http://www.baumhydraulics.com/calculators/spk_ratio1.htm
Simples *smiley*
