Home > General Chat > fixed mach advance along with vacuum advance
turbo hogster
Member #: 178
stowmaket suffolk
has any one tried this, im currently running 30 deg fixed avance with no vacuum.
butif i connect up the vacuum advance this should give me more ignition adv for cruising so increase economy but when i boot it the boost will should push it back along with the spring back to 30 deg, well thats the theory.
does any one no how much the vac advances the ign in deg of the top of there head, i know i may need to back of the ign slightly as not to give it to much.
If you have a look at the vacuum can it should have a number stamped on it that indicates the max advance it will produce at full stroke.
