| Home > Help Needed / General Tech Chat > Who's running a standard set of helical gears and what power? | |||||||
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
8th Mar, 2014 at 12:07:39pm
I have a 1:1 set of straight cut drop gears and a 3:1 FD with 4 pin diff.
Edited by madonminis on 8th Mar, 2014. BHP sells engines, but Torque wins races! |
8th Mar, 2014 at 12:14:40pm
We ran them on the metro van up to about 160 bananas. Smashed the cage on the first motion shaft bearing doing emergency starts at Avon. On 11th Feb, 2015 robert said:
8th Mar, 2014 at 01:15:07pm
was that with a set of straight cut drops and a decent diff andy? BHP sells engines, but Torque wins races! |
8th Mar, 2014 at 01:35:37pm
Not sure if Robert has a full helical set, I'm sure it's been mentioned before. On 26th Jan, 2012 Tom Fenton said:
8th Mar, 2014 at 03:28:09pm
S/c drops, 4 pin diff and 3.1 cwp on 13s On 11th Feb, 2015 robert said:
8th Mar, 2014 at 03:41:17pm
I ran a 2.9 with std drops and 120bananas no worries. Would last forever at that. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Mar, 2014 at 07:26:49pm
I run helical drops and a straight cut clubman set . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
8th Mar, 2014 at 09:38:10pm
go the way roberts gone
8th Mar, 2014 at 10:13:25pm
As much as I respect roberts input, I would go Sc drops over about 180hp,
Edited by Joe C on 8th Mar, 2014. On 28th Aug, 2011 Kean said:
104 Posts Member #: 10210 Advanced Member Durban, South Africa |
9th Mar, 2014 at 05:57:36am
Helical drops, helical box, 3.1 diff and 130nanas. Touch wood haven't had any failures as yet with 2 years of abuse. Life is always a matter of opinion and quite frankly, no ones opinion really matters. |
9th Mar, 2014 at 11:25:46am
I think a lot is down to the raw torque, and how the box is put together so here is no stack up of tolerances. I run a supercharger and I don't care the TB is on the wrong side.
10th Mar, 2014 at 10:03:55am
how do you mean graham? is this meaning lash in the gear set?
clubman set and helical drops, the drops and the clubman set are roughley the same price ............... with the clubman set you get better ratios ............... also in combination with helicall drops its a alot less noise, with the clubmanset i would say only 4% over helical gearset ............ i have stripped boxes and theres no wear with this combination even at 190 hp levels. and over 10k miles.
