Home > General Chat > ROOF REPLACEMENT
PEP
Member #: 1145
North Wales
Awright people??? Ive got a webasto sunroof on my car and don't really want it in there.
Has any got a idea how much a bodyshop would charge to sort the roof???
Plus would it be just around the sunroof or the entire roof replacement???
Thanks for any help*tongue*
I replaced the whole roof skin on my car. It's not difficult just a little awkward and time consuming. Probably a good days labour to replace it in a pro shop.
I wouldn't even consider trying to fill the hole in the roof in. You'll never be able to weld that distance without some amount of distortion.
Genuine carbon fibre?
PEP
Member #: 1145
North Wales
thanks for that. its a 1972 clubby.i like the idea but would it look right with carbon fibre??
Just paint it ?
eden7842
Member #: 8852
leicestershire
Pep, if the roofs in good condition I could have someone who may well want it
Good luck drilling. All those spot welds out what a knob ache
Best way to remove the roof skin is to cut is as close as you can to the welded seam, then use a small sanding disc on a die grinder to thin the metal down. Using some pliers/grips you can then just peel the remaining lip off and just sand the welds flat ready for the new skin. I found my roof skin was a good snug fit and only fit in one place, so it was clamped and spot welded in place every 10mm 15mm and then sealant put around the edges into the gutter.
Nick warwick
Member #: 8926
Sheffield
Spot welds take ages to drill out as BENROSS says
graemec
Member #: 1424
Carnforth, Lancs
I thought they were continuously 'roller' welded? I'm sure later cars are
Depends on the age of the car. My 78 shell was spot welded, but some of the shell sections I used were rollered.
I just spot welded every 5-10mm.
