Home > Help Needed / General Tech Chat > inlet manifolds for turbos
All-agroA+
Member #: 10611
Its probably been said plenty of times by now and I have searched on here for the answer but cant seem to find, what manifolds fit with the metro turbo exhaust manifold?
Do they have to be designated turbo inlet manifold or can I use a normal Ally heated inlet?
I think spi and mpi inlets dont fit?
Any knowledge would be grateful as theres quite a lot of manifolds on ebay :s
Ta nath
Kean
Member #: 341
aka T2clubby
South Staffs
You can use a normal non turbo unit.
Some inlets wont clear the ex manifold, the NA MG Metro for example. Also the flanges are thinner so you'll need to make up some stepped washers if you use a non Turbo inlet.
Phil.
You are best off using the Metro turbo inlet due to the reasons above.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i can check my TITAN Motorsport one for fitment in the std metro mani if you like? i think it did fit from memory? just decided on a custom ex instead
