Home > Help Needed / General Tech Chat > verto dismantle problem
Rammie2000
Member #: 10190
belgium
hi
i'm stripping a 998 a+ block and have now bumped on the problem that the verto (spring) plate is not well a lined. so the holes in the spring plate dont match the holes in the flywheel and there fore i cant place my puller on it.as i see it i have to options knock the fly wheel of or get the springs (fingers) bent up or cut of so i can put the 3 bolts in place for the puller. anny other options or what one would be the best bet?
Drill the rivets out that hold the spring plates on. You can then refit the springs using the same method as the RTS clutches. The rivets are really soft so will be easy enough to drill with a piston drill.
Piston drill.... Nice
Haha yeah it's a special drill for lightening your pistons. *happy*
Rammie2000
Member #: 10190
belgium
Thats tap wire into them and bolt them down? Nice idea mister piston drill
