Home > Help Needed / General Tech Chat > Wrinkle paint conundrum.
I have some hycote wrinkle paint, now this stuff scares the shit out of me lol.
How is the best way to use it? I will be spraying aluminium.
The can says
2 coats 10 mins between each. After 4hrs apply a heavy coat! ( how heavy)
I did this once before and it looked dog tuard! So I sanded it back and went for a matt paint.
Any help would be nice.
Simon.
Use this stuff
http://www.ebay.co.uk/itm/2X-VHT-BLACK-WRI...=item51b9754603
I use it at work - its brilliant. Do as it says on the tin - you cant go wrong
I'm sure I've heard of the use of a hot air gun either before or after application helps it
It does Carl, before and after
Rammie2000
Member #: 10190
belgium
Tje thin coats are to make grip on tje surface then the thick coat is as thick you can spray without having a runner. So you get a tension on the surface of the dring paint creating the wrinkle
I may have a look at that stuff then paul.
As that reads paint it and pop it in the oven at gas mark 6 for 20min jobs a goodin.
Edited by madmk1 on 11th Mar, 2014.
jonny f
Member #: 9894
Dorking
The VHT stuff is the one to go for!
Works a treat.
All sounds a bit heavy
madonminis
Member #: 9371
East Yorkshire
Check my build thread Simon. Speedwell one.
I have just found a how to in the CBS catalogue *smiley* looks like I will have to do this when I get back from my next trip away.
tadge44
Member #: 2500
Buckinghamshire
From my experience with this stuff the secret is to get an even coating because the size of the wrinkles varies with the thickness of the paint coating.
I made a right mess (twice !) of a dashboard until I read this tip.
hot air gun works but it can be tricky to get the wrinkle even, you need a more uniform heat, Ideally an oven on low.
definatly go for the VHT stuff, some brands are crap.
and be warned it stinks!
cradley_heathen
Member #: 10784
i did the rocker cover on a twin cam rocker cover a few years ago, it was really patchy. some areas were smooth and others had a really nice rinkle.
i was about to give it another coat to see if that helped when my friend suggested wiping it over with a cloth and some celulose thinners first, and just as i wiped it over, it made the whole thing go really nicely rinckled.
shane
Member #: 1246
Lowestoft, Suffolk.
I appreciate this is dusting off an old thread , but does anyone know what the recommended product was?
Shane
DILLIGAF
Member #: 9128
VHT Wrinke Paint, frost sell it:
https://www.frost.co.uk/textured-paints/
Demontweeks also do it:
https://www.demon-tweeks.com/demon-tweeks-v...wE&gclsrc=aw.ds
shane
Member #: 1246
Lowestoft, Suffolk.
Cheers, I just wanted to make sure that the one Paul recommended was the VHT product.
Shane
