| Home > Introduce Yourself > New to this but started my project 5 years ago then abandend it! | |||||||
4 Posts Member #: 10720 Junior Member |
15th Mar, 2014 at 06:14:22pm
Hi my name is Adam Blaikie and I started my project 5 years ago. At the time I fitted the bulkhead box trial fitted the engine then had the car painted. Basically he made an arse of it and the cars new name is 50 shades of grey! That pissed me off and I had also started a self build house project so it sat there since. The engine I had got was rebuilt and run in but he had spent all the money on the engine and the car was bit of a rust bucket. Trouble is I can't even remember the spec now and want to get it up and running for my wedding at the end of june! Whats peoples advice I want to risk it and install the engine. Keep boost low and see how it goes. I don't mind pulling the engine back out in a year I just want it back on the road or I am never going to get back into it! The wedding is a good goal. |
15th Mar, 2014 at 07:54:15pm
How do. On 11th Feb, 2015 robert said:
15th Mar, 2014 at 08:36:16pm
Welcome to tm.
15th Mar, 2014 at 08:58:56pm
a warm welcome! you could install it and keep the boost under 8psi and see how it goes ?
16th Mar, 2014 at 10:03:35am
Will it likely b ok after sitting? It turns over fine by hand. 8psi a safe level? Is there anyway boost could have been adjusted. Without fitting a bleed valve? |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
16th Mar, 2014 at 11:02:35am
if it turns over by hand thats a good start 8 psi is standard metro turbo so safe bet Done now needs redoing lol |
16th Mar, 2014 at 01:55:09pm
Get an oil pressure gauge fitted temporarily and connect the starter and earth up, back fill the oil pump (take the big bolt out of the pipe and fill the hole with oil, then turn the engine backwards by hand - repeat a few times as the oil disappears).
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
16th Mar, 2014 at 07:24:04pm
Welcome, hope you don't end up pushing it to the church They don't die, they just get faster! |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
17th Mar, 2014 at 07:41:09am
Welcome What the mind can conceive the mini can achieve
17th Mar, 2014 at 10:07:40am
Welcome. ................ To your deep pockets mwhahahaha............ Own the day
20th Mar, 2014 at 07:49:21pm
Gonna keep fingers crossed and see how it goes! |
24th Mar, 2014 at 03:03:57am
Building a Mini is like a bad habit, its so so bad for you but oh the end feeling is sooo sooo good you just can't keep from doing it over and over and over……... Own the day
25th Mar, 2014 at 12:02:20am
On 24th Mar, 2014 Mr Joshua said:
Building a Mini is like a bad habit, its so so bad for you but oh the end feeling is sooo sooo good you just can't keep from doing it over and over and over……... perfect! quote
