| Home > Help Needed / General Tech Chat > 998 engine compression test results | |||||||
57 Posts Member #: 10219 Advanced Member |
15th Mar, 2014 at 06:29:08pm
Just wondering if my compression is good, it showed 12.5 bar /181psi on 2x cylinders and 13bar/188psi on other two . It's a 998cc done 100k . |
15th Mar, 2014 at 06:54:04pm
I'd be happy with that 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Mar, 2014 at 07:00:11pm
That looks fine.
15th Mar, 2014 at 07:01:10pm
Would I be able to add a turbo to this engine if I changed oil, water pump etc with some new bearings and add a new x pin diff ,change the head for lower compression . |
15th Mar, 2014 at 07:09:52pm
There's no reason it can't be Turbo'd. Have a look here for a guide to a simple conversion:
15th Mar, 2014 at 07:15:12pm
Would a recon box be better for a turbo build , mine is fine goes into gear fine just whines when driving and stops when clutch is down, idler bearing ??. |
15th Mar, 2014 at 07:36:50pm
I would not be turboing a 100k power unit without full rebuild. On 7th Oct, 2010 5haneJ said:
15th Mar, 2014 at 07:37:14pm
Good compression for such a high mileage really. On 7th Oct, 2010 5haneJ said:
15th Mar, 2014 at 08:50:39pm
Is it a no go for a turbo then as I have a t2 mounted on a metro manifold ready to go . I've always been told the 998cc are bullet proof little engines . |
15th Mar, 2014 at 08:54:40pm
I know the mileage is high but it's been serviced every 6k from new . And would change bearings , thrust washers , head , water /oil pump , new clutch , gearbox x pin diff . |
15th Mar, 2014 at 09:10:51pm
At the end of the day, if the bottom end goes pop, its just a standard 998 to replace. I'd give it a go. |
15th Mar, 2014 at 09:29:41pm
Do it! On 11th Feb, 2015 robert said:
16th Mar, 2014 at 09:07:59am
Had a leak down test done? that give a better reading over a compression test to how is leaking past valves and piston rings. |
16th Mar, 2014 at 11:07:22am
No I have not how is this done/ or where can I have this done ? |
16th Mar, 2014 at 08:32:47pm
Local garage norm can do them just give it a google but basicly move piston to TDC and fill with air and then watch how much gauge moves down that give a good indercation to the state of the rings valves and gaksets |
17th Mar, 2014 at 09:01:26am
with those results and you know otherwise it runs fine, just do it.
17th Mar, 2014 at 06:30:55pm
Wil how long did your last before it went bang , and would a x pin and new gearbox ,new clutch be an idea for 100bhp and of course swap the head (12g295 ),mg metro cam will this get the power . And will it get into high 7 seconds region . I have a mini city 92 stripped about 40kg from it and run 13" wheels . |
