| Home > Help Needed / General Tech Chat > Dump valve fitting | |||||||
57 Posts Member #: 10219 Advanced Member |
24th Mar, 2014 at 08:20:16am
I know that a dump valve can be drilled and fitted to plenum but can it also be fitted on one of the intercooler pipes? As I have brought an escort rs turbo series 2 intercooler and the hoses include a fitting for dump valve . Could I connect these hoses on and then join on to extended them to them plenum and t2 turbo I have or do I need to buy new hoses and et one of the alloy inline dump valve fittings . Sam |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
24th Mar, 2014 at 08:22:14am
It can fit anywhere between the carb and turbo BUT is best fitted as close to the carb as possible. What the mind can conceive the mini can achieve
24th Mar, 2014 at 12:29:03pm
Ok cheers for that you don't know by any chance the size hoses into the t2 turbo and the Metro plenum and do you need a reducer at all . |
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
24th Mar, 2014 at 12:37:46pm
Metro plenum doesn't have a take off for a dump valve. Anyone who has one had had it custom made mate. BHP sells engines, but Torque wins races! |
24th Mar, 2014 at 01:05:40pm
No sorry I'm after the size pipe in which goes onto the plenum for the intercooler and the size for t2 turbo . Cheers |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
24th Mar, 2014 at 02:38:59pm
Is yours a standard metro plenum? With the standard ones the inlet points straight down towards the turbo making it difficult to get to an intercooler.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
24th Mar, 2014 at 03:12:07pm
No the metro plenum has been modified for easy use of intercooler . And yes please if you wouldn't mind. |
24th Mar, 2014 at 07:29:12pm
The sizes on mine are 60mm for the inlet and 53mm for the outlet. I don't know what the plenum size is though, so I don't know about reducers etc. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
24th Mar, 2014 at 07:58:03pm
On 24th Mar, 2014 sam138 said:
No the metro plenum has been modified for easy use of intercooler . And yes please if you wouldn't mind. You could always measure your plenum then. Just need the size for the t2 BHP sells engines, but Torque wins races! |
25th Mar, 2014 at 08:23:03am
Ok cheers for that ordered all my piping just wondered what side the dump valve needs to be is it the cooled side going into plenum and have it close to the plenum on the hose . |
25th Mar, 2014 at 08:34:54am
going to have mine dump before the turbo inlet and relese pressure from right befor the carb in the alu pipe via weled on 1" pipe whole thing is in 1" ID should get the job done
