| Home > Help Needed / General Tech Chat > Drop gears oil jet | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
25th Mar, 2014 at 09:23:07am
As assembly of my engine is coming close (finally!) I am thinking about last things to sort.
Dazed and Confused.... |
25th Mar, 2014 at 10:42:04am
id thought about doing something like this along the lines of blocking the oil pressure releif where it dumps into the box and re drill the end of the block to intercet the origanal hole
25th Mar, 2014 at 12:44:13pm
Sprocket has done this in the past. There will be pictures somewhere. On 11th Feb, 2015 robert said:
26th Mar, 2014 at 01:44:27am
Just don't squirt directly onto the mesh. 45deg before would be a safe target. On 17th Nov, 2014 Tom Fenton said:
26th Mar, 2014 at 08:16:41am
Thanks for the reactions guys.
26th Mar, 2014 at 08:41:19am
I think you are talking about a pressure fed idler bearing aren't you? If something is worth doing, it's worth doing half of. |
26th Mar, 2014 at 12:36:11pm
On 25th Mar, 2014 apbellamy said:
Sprocket has done this in the past. There will be pictures somewhere. I think you might be getting confused with the pressure fed idler thrusts Not my idea by the way, Turbo Harry takes all the credit.......
26th Mar, 2014 at 01:39:48pm
It is quite possible I am (hence my signature.... :) )
26th Mar, 2014 at 04:05:26pm
Yes, if you want to squirt into the gear me3sh to help the gears, perhaps also assist in chatter, then don't squirt into the mesh... Too much oil in the mesh is bad. Even inside the gearbox at high speed the gears beat th oil out of the way so there is a "wall" of oil around the gears, but not in the mesh. If you force excessive amounts of oil into the mesh with no method of escape prior to the flanks contacting, then you will create a whole load more problems than you were attempting to solve. On 17th Nov, 2014 Tom Fenton said:
26th Mar, 2014 at 06:55:45pm
On 26th Mar, 2014 TurboDave16V said:
Yes, if you want to squirt into the gear me3sh to help the gears, perhaps also assist in chatter, then don't squirt into the mesh... Too much oil in the mesh is bad. Even inside the gearbox at high speed the gears beat th oil out of the way so there is a "wall" of oil around the gears, but not in the mesh. If you force excessive amounts of oil into the mesh with no method of escape prior to the flanks contacting, then you will create a whole load more problems than you were attempting to solve. Supersonic oil.....we don't need anymore of that lol On 26th Oct, 2004 TurboDave16v said:
26th Mar, 2014 at 08:44:29pm
Yes, if you want to squirt into the gear me3sh to help the gears, perhaps also assist in chatter, then don't squirt into the mesh... Too much oil in the mesh is bad. Even inside the gearbox at high speed the gears beat th oil out of the way so there is a "wall" of oil around the gears, but not in the mesh. If you force excessive amounts of oil into the mesh with no method of escape prior to the flanks contacting, then you will create a whole load more problems than you were attempting to solve. That's what I was thinking, forcing that extra layer in between meshes might create isssues. Best feed it from the side... Supersonic oil... :
Sounds like it might theretically do something but in practice not that much.. We'll have to live with the whining then.. :) Cheers guys Dazed and Confused.... |
432 Posts Member #: 7856 Senior Member Essex |
26th Mar, 2014 at 11:06:55pm
On 26th Mar, 2014 Yo-Han said:
Though I am pretty convinced there was a discussion about reducing SC whine aswell.. nothing might have come out though.. I remember this too and also thought it was Joe that mentioned it, maybe message him and see? |
27th Mar, 2014 at 07:43:22am
thats a sweet looking mod to the thrust faces perhaps this could be a fix for roasted housings as well |
27th Mar, 2014 at 08:24:36pm
Yes this was me.... sort of.
27th Mar, 2014 at 08:55:54pm
You can buy an additive but I can't remember who by, but the demonstration for it is three plastic gears in a clear box and the additive helps keep a thin film of oil on the upper gears, whereas without it barely reaches the top one. Someone may know the brand and product. On 26th Jan, 2012 Tom Fenton said:
27th Mar, 2014 at 09:07:07pm
Addatives........ Hmmmm......... Skeptical On 26th Oct, 2004 TurboDave16v said:
27th Mar, 2014 at 09:15:27pm
you can just make out the drilling in this pic, above the water take off is the main gallery plug ( gold coloured) and above this and slightly left is the drilling I added,
1st Apr, 2014 at 03:03:57pm
Thanks for that Joe.
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
25th Jan, 2021 at 11:30:36pm
Bit of an old thread dust off.
113 Posts Member #: 11786 Advanced Member |
3rd Feb, 2021 at 07:31:27am
Nothing to add from me, just throwing some pictures from turbo harrys build in.
3rd Feb, 2021 at 09:25:23am
I had found Harry's site after some further digging, thanks though.
