| Home > Help Needed / General Tech Chat > Crank Pulley Rubber Worn Out? | |||||||
168 Posts Member #: 10666 Advanced Member California, USA |
28th Mar, 2014 at 02:06:22am
Hi All,
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
28th Mar, 2014 at 03:02:46am
I think you need a new one...
Pedro Silva
166 Posts Member #: 8952 Advanced Member Athens Greece |
28th Mar, 2014 at 05:24:58am
Try cutting a bit of the rubber and see if the cracking continues inside, if not then it's ok to use.
28th Mar, 2014 at 03:01:12pm
Roger that, thanks for the replies. I think I'd rather not risk it coming free.
28th Mar, 2014 at 03:15:51pm
you also need balancing the pulley
Pedro Silva
28th Mar, 2014 at 03:15:53pm
Pedro Silva
28th Mar, 2014 at 04:56:15pm
Roger that on the balancing, that definitely makes sense.
28th Mar, 2014 at 05:10:23pm
The idea of the rubber (?) bonded pulley is that it damps out harmonic vibrations on the crankshaft.(it is sometimes referred to as a harmonic balancer)
28th Mar, 2014 at 05:17:09pm
That makes sense, I should note that this is for a 998 engine which, I believe, were fitted with the lighter stamped version or the harmonic style depending on the year. I'm not sure if the harmonic balancer is needed for these.
28th Mar, 2014 at 05:35:15pm
and you cant balance the damper Yes i moved to the darkside |
28th Mar, 2014 at 07:38:17pm
Brett, why not? Pedro Silva
29th Mar, 2014 at 08:35:53pm
If its a 998 then most didn't have dampers. I would say you will be fine without one. Just fit a trigger wheel in addition to the pulley. On 7th Oct, 2010 5haneJ said:
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
29th Mar, 2014 at 09:44:03pm
Fit a new one
29th Mar, 2014 at 10:36:13pm
Or you can try Selby trigger wheel...
Pedro Silva
29th Mar, 2014 at 10:58:58pm
Still curious to hear about why the damper can't be balance but that Selby trigger wheel looks awesome. I wonder if I can get a verto option? |
30th Mar, 2014 at 09:01:28pm
Hes quite active on here
30th Mar, 2014 at 10:08:02pm
Of course you can and must balance the damper. However, when it's as fucked as the pictured one, it might need it again.
31st Mar, 2014 at 01:32:58pm
I thought that the damper should be balanced. Definitely binning the one I have, now I'm just considering my other options.
31st Mar, 2014 at 03:39:37pm
As I look to sourcing these, I'm wondering if a Midget/Sprite would fit. They look awfully similar and are much more available and cheaper here in the states.
25th Apr, 2014 at 09:57:45pm
So I ended up not taking any gambles and getting the new damper.
