| Home > Help Needed / General Tech Chat > smokey new engine | |||||||
389 Posts Member #: 9751 Senior Member Derbyshire |
30th Mar, 2014 at 09:13:48pm
Gents,
30th Mar, 2014 at 09:15:19pm
We ran total seal rings on the van with no issues. If something is worth doing, it's worth doing half of. |
30th Mar, 2014 at 09:23:27pm
Form their web page
30th Mar, 2014 at 09:31:20pm
I've been on their website and didn't bloody find that. cheers graham.
On 30th Mar, 2014 gr4h4m said:
Form their web page http://www.totalseal.com/Techpage.aspx ASSEMBLY LUBRICANT Specifically engineered by Total Seal® to provide proper ring lubrication during initial break in. AL4’s clinging nature allows it to stay in place until the engine is placed in service. During initial start up it burns off quickly and cleanly leaving no residue. Used on it’s own or combine it with Quickseat® for the most advanced piston and ring assembly lubrication available helping to assure fast and complete ring seating. Ring Seating When first starting your engine to ensure proper ring seating, do not allow the engine to idle for long periods at a time. It is a good idea to mildly load the engine as soon as you can. Highway driving is a good way to properly seat the rings quickly. Do not idle the engine as idling does not break in any engine. Total Seal ® DOES NOT recommend the use of synthetic oils during break-in. After 2000-3000 miles on the street, or one night racing on the track, the rings should be adequately seated so that any oil you prefer can then be used. |
30th Mar, 2014 at 09:33:52pm
now I've re-read the page i can easily see it. I think i was frantically flipping web pages looking for answers yesterday. |
30th Mar, 2014 at 10:13:11pm
I think sprocket had a post on bedding them in... I can't find it. I run a supercharger and I don't care the TB is on the wrong side.
31st Mar, 2014 at 06:33:44am
All the total seal rings i have baught have all come with fitting and bedding in instructiins in the box On 26th Oct, 2004 TurboDave16v said:
31st Mar, 2014 at 06:39:47am
Oh and totalseal suggest that if you cannot get hold of their assembly lubricant or quick seat products to use wd40 instead..
31st Mar, 2014 at 07:26:57am
Thanks for the suggestion sprocket, this is not my first rodeo though. I have followed all instructions regarding building, ring gaps, honing etc. |
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
31st Mar, 2014 at 07:34:19am
Personally I have never had any luck with just changing rings.
Edited by Jawd on 31st Mar, 2014. |
31st Mar, 2014 at 07:56:50am
This thread almost exactly mirrors the one I posted some years ago and I got the same advice then - it works.
31st Mar, 2014 at 08:18:15am
Nice one Tadge. I have been advised by quite a few people saying, stop worrying and simply drive it. I am quite a detailed person and like to know how and why though. I have built and still build many many engines from minis to big V8,s making 600+BHP, so i don't like it when people do work when you don't have to, i.e. boring out and fitting larger pistons when if the block can be measured accurately and honed correctly and is within acceptable tolerances it is perfectly serviceable.
On 31st Mar, 2014 tadge44 said:
This thread almost exactly mirrors the one I posted some years ago and I got the same advice then - it works. Tom Fentons comment was "stop fretting and get out there and drive it " I did just that and had no more smoking. And I don,t agree with Jawd as I have rescued many engines with new rings only. Edited by mossy2a on 31st Mar, 2014. |
31st Mar, 2014 at 08:25:05am
Only my experience Tadge or I may have had other issues I suppose.
31st Mar, 2014 at 08:29:53am
Get the fuelling/timing sorted then go and give it some boot first.
1st Apr, 2014 at 08:58:57am
are those pruduct actualy recomended by you guys that do fresh builds all the time?
1st Apr, 2014 at 11:07:57am
I contacted Total seal and i also visited lots of forums before hand where numerous people have used these rings on many different engines, new and old bores. The advise is as long as the bores are honed and sized correctly and the rings are fitted correctly you should be ok. There is a lot of people on many forums worrying about this topic and higher than normal oil consumption. I have contacted total seal again and they have said to simply use the engine, preferably under load at RPM 2.5K+ |
1st Apr, 2014 at 11:29:22am
I'll say it again. What makes you think the smokey engine is as a result of the rings? On 26th Oct, 2004 TurboDave16v said:
1st Apr, 2014 at 11:37:19am
A freshly blown turbo seal will not neccesarily leave oil in the intake or exhaust, but there are a few signs; such as a black, almost tar-like gummy mess around the turbo core or downpipe.
1st Apr, 2014 at 12:18:16pm
there is an oily residue on the pistons. |
