| Home > Help Needed / General Tech Chat > Mig welds | |||||||
57 Posts Member #: 10219 Advanced Member |
2nd Apr, 2014 at 06:54:17am
Recently started practising with my mig got it about right just wanted opinion on my welds if they are right . Picture link shows how I started with max 1 power and blew through metal , then set on min 2 power and is about right with 6 wire speed . Do they seem right or is there adjusting to do . https://m.flickr.com/#/photos/88561210@N05/13576118084/ |
2nd Apr, 2014 at 07:25:13am
metal needs to be cleaner and a little more gas too. all the welds have contamination or bubbles in them . im self taught tho so cant offer "proper" advice turbo 16v k-series 11.9@118.9 :)
2nd Apr, 2014 at 12:00:50pm
As said above, cleaner metal, more gas (doesnt look like you have any tbh), and steady your trigger hand with the other. Keep practicing a lot before you weld a car I seriously doubt it! |
2nd Apr, 2014 at 05:57:26pm
Thanks seem to be having a problem with building up weld I have checked a bleed valve on the gas bottle and pressure comes out . Could this be the wrong gas or too old as I came with the welder before I brought it . The gas bottle is a sealey co2 gas |
2nd Apr, 2014 at 06:37:37pm
Ideally you want argon/CO2 mix. Try more pressure rather than more flow then gradually turn up the flow
2nd Apr, 2014 at 06:52:12pm
Ok how do you up the pressure on a mig |
2nd Apr, 2014 at 08:27:49pm
Its on the gas regulator I seriously doubt it! |
2nd Apr, 2014 at 08:32:54pm
I get the impression he's on disposable bottles which will only have a flow valve rather than a pressure reg |
2nd Apr, 2014 at 08:48:15pm
Are you welding outside? |
3rd Apr, 2014 at 07:10:13am
Yer I have been using disposable bottles and welding outside . |
3rd Apr, 2014 at 07:31:08am
its too windy and hold the nossle closer to the wprkpiece :) turbo 16v k-series 11.9@118.9 :)
3rd Apr, 2014 at 08:13:20pm
Will the gas bottle still have pressure even when empty, as I think the bottles I have are empty as the welds keep going flat and not build and blowing holes . Will pick up a new one tomorrow . |
![]() 270 Posts Member #: 69 Senior Member Coventry |
4th Apr, 2014 at 11:54:07am
you can hear it as it comes out before you strike, which you wont know to hear if you have never heard it when its right! make a shield around what your welding but be careful its doesnt catch fire, welding a small repair outside on a windy day a corner of a cardboard box held up wind is useful, did that a few times racing when it was blowing a gale trying to do repairs... |
4th Apr, 2014 at 08:32:13pm
As shown I. The picture can you only create small welds on mini car panels as it just blows holes it's an old a panel only about 1 thick . My welder just won't set right , brought a new bottle of gas today . Just won't build up without blowing even on lowest setting . |
