Home > General Chat > looking to sell but whats it worth
mini.cooper998
Member #: 3772
Wigan
as the title says, iget so little time to work on the project that the grim realization has set in that I would be better selling but whats it worth
please advise
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=489679
shell fully rebuilt with
New full floor tig seam welded for extra strength
New inner ( part of new full floor and outer sills )
Tubbed Arches
Roll Cage brace's fitted rear arches
Rear turrets braced across for strength by Vickers
Rear fuel filler hole welded and filled smooth
New rear valance
New rear heal board
Fibre front (permanent)
Beam rear axle
custom rear shelf by Vickers
Customer rear seat squab infills by Vickers
Gaz Coilovers front excellent condition
Gaz Coilovers rear excellent condition
Rebuilt rear radius arms
Rebuilt rear brakes
12" disk setup front ( No calipers )
Adjustable bottom arms( On Car )
Adjustable tie bars ( On Car )
All red anodized red aluminium solid mounts
Turbo box fitted
New scuttle panel
New a Panels
All underside, under bonnet and boot area painted in Grey/Beige Machine enamel for hard wearing
Fiberglass MK 1 boot lid double skin
Lightweight doors excellent condition ( No Windows )
sat on 5x10 Weller wheels and fully rolling
Parts included
1275 engine good condition average mileage ( head removed for inspection )
metro turbo complete with actuator and manifold ( some play in shaft )
Genuine metro turbo carb and inlet manifold and plenum
maniflow downpipe
Twin Ducati 996 rear cans
New fuel regulator
New headlamps H4 conversion
New Mini Miglia wheel arches ( not trimmed or cut )
New plastic bowls and rims
New MK1 Austin cooper grill
New MK1 Moustache
New MK1 whiskers
steering column
alloy steering wheel
2 full looms
all brake and clutch cylinder assembly's
stainless brake cylinder plates
custom center dash with smiths MGB gauges ( all new bezzles and refurbd internals )
all glass
full set of new seals
Nippon denso race alternator
Full Mega Jolt setup including trigger wheel and all edis parts ready to go
New Black lightweight mirrors
Interior Mirror
No interior parts as such but lots of nuts bolts fastening spares etc in boxes
only bit needed for spraying is the door gap on drivers side sorting and boot lid fitting fill and prep and ready for spray.
what do you recon its worth
thanks
mini.cooper998
Member #: 3772
Wigan
Can anyone give me an idea of what its worth. I cant stick it in for sale without a guide price.
Kean
Member #: 341
aka T2clubby
South Staffs
Looking at the build thread and the effort you have put in I think you should find a way to keep it.
hard to put a price on it really. unless your desperate for cash and space, would it not be worth mothballing it until you've got time for it again. reality is it worth less than your time and effort to get it this far
mini.cooper998
Member #: 3772
Wigan
unfortunately I have now taken on a more expansive role at work which gives me very little spare time. I have to give in to reality that I will not get time to finish this and so must sell be it now or in 5 years time when its probably 20hours further on.
What I don't want to do is stick it on EBAY and watch it go to some dead head who believes he can finish it but lets it sit in a garage and be bastardised before being scrapped. I would idealy like to sell to someone on here who I believe could do it justice. Problem I have is the website needs a price to list and I don't have a clue where to start.
I appreciate the posts and will almost certainly call in and drool over posts even when I no longer have it.
philc
Member #: 1346
bromsgrove
You have clearly put some work into it, perhaps it is better to put a price on each item you have and sell separately, from what I see with people selling ongoing projects is that you get more for selling the item separately, I appreciate it is a ball ache but maybe this is your best option. Ebay is pot luck you get what people are willing to pay
Edited by philc on 11th Apr, 2014.
Evoderby
Member #: 9987
Amsterdam
Excellent news, taking a next step in your carreer is not unfortunate at all! As others have said it's best to sell as parts.
Realistically the shell is worth less than the new floor you've put into it....remember the fully prepared shell that sat on here for ages? It was painted (white) had a full weld in cage and went for something like 1500 after sitting for a year.
The beam, coil overs and subframe should be an easy sell. So would the wheels and turbo setup....just
do a search on here to get an idea of going rates.
Edited by Evoderby on 11th Apr, 2014.
mini.cooper998
Member #: 3772
Wigan
ok cheers
mini.cooper998
Member #: 3772
Wigan
does anyone think 2 grand is too much
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
in Australia id buy that up so fast
mini.cooper998
Member #: 3772
Wigan
I can crate if you fancy paying postage
