| Home > General Chat > primary and center section diameters? | |||||||
9th Apr, 2014 at 05:01:45pm
Hi, im using a 1800 vauxhall block with jenveys.. even with other modification it wont see over 200 bhp, im having a manifold made but what primary and center section diameters should i go for?
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
10th Apr, 2014 at 11:16:51am
have you got more specs ( the more the better.. stroke/CR/etc etc preferably flow numbers or even better dyno numbers) i could run it through pipemax and see what it spits out. it's pretty accurate most of the time.
10th Apr, 2014 at 01:28:04pm
Thanks
10th Apr, 2014 at 03:29:47pm
I also need valve and stem diameters, cam timing numbers (and rocker or followers ratio if any) and lift.
10th Apr, 2014 at 06:15:42pm
Edited by MarkGTT on 10th Apr, 2014. |
14th Apr, 2014 at 05:37:45pm
those valves are tiny..
Edited by Sir Yun on 14th Apr, 2014. That sir, is not rust, it is the progressive mass reduction system
14th Apr, 2014 at 06:17:13pm
14th Apr, 2014 at 06:43:50pm
thanx Robert noice curve.. and quite big flow numbers on the intake.
14th Apr, 2014 at 06:59:41pm
Thanks yeah clearly the valve size above is wrong.. I blame the cut and paste on the iPhone. :)
