Home > General Chat > wideband controller
nky_84
Member #: 9213
Scotland
Hi guys,
I'm looking at lamda controllers to monitor wideband signals through the ECU. I dont need a gauge, sensor or any of the other stuff people try to bundle along with them. Also find it strange that not many UK companies seem to do this kind of thing.
The below seems to be the most cost effective option but im unclear if this is all i would need to enable the ECU and laptop to capture the wideband signal.
http://www.14point7.com/products/spartan-lambda-controller
Anyone know of any other alternative options that just do the basics?
Nick
jakejakejake1
Member #: 10010
Northants
That gives out a 0-5V signal, so as long as your ECU can log a 0-5V then you should be fine.
In the software you will have to scale it to display the 0.68-1.36 lambda that the 0-5V represents but I think thats it.
Plus you would need to wire it in yourself but that won't be hard.
Another option is to use this AEM wideband which logs quite a few different parameters as well as acting as a fail safe
http://www.aemelectronics.com/wideband-air...lsafe-gauge-84/
The spartan seems quite popular amongst the Megasquirt community (just search spartan on the MSExtra forums and you will find lots of positive recommendations).
I am in the process of changing over to 14point7 controllers (SLC OEM modules in my case) as the products seem very good but the only word of caution is that 3 years ago (when I originally intended to make the change) I had some very bad customer service and about 18 months ago someone else on here (I think it was Jimster) also suffered. They do appear to have been "one offs" though and, as I say, the Spartans do have a very good reputation on the MSExtra forums.
The only other company that I'm aware off that will sell their controller without the sensor, gauges etc, is TechEdge.
Also very good quality (I currently use their stuff) but their closest equivilant to the Spartan is quite a bit more expensive.
nky_84
Member #: 9213
Scotland
Yes, its the Specialist Components Typhoon ECU, which accepts 0-5V signal.
Spartan seems significantly cheaper than anything else on the market, so i think i'll take a punt!
nky_84
Member #: 9213
Scotland
anyone know if this will be liable for duty charges etc and what that additional cost would be?
Technically it is liable for duty and VAT but it's not that far over the limit.
I just received two SLCs from him last week at $80 and with the customs form filled in correctly mine went straight through.
I've also had more expensive stuff from Jean (also Canadian, obviously) and never been charged.
Same for Paul and Graham and the expensive stuff was in a fairly large box for all of us.
UK customs seem a lot kinder on stuff from Canada than stuff from the USA.
So there is a good chance you will be OK, but you may be the unlucky one......
If you do get caught it's VAT (20%), duty (probably 3% depending on how it's labelled) and any RoyalMail (or ParcelForce) handling charges.
But past experience says it's unlikely.
Still, I always budget for it and feel good when it doesn't happen.
EDIT - deleted my canadian dollars bit, the payment was actually in US$
Edited by Rod S on 10th Apr, 2014.
nky_84
Member #: 9213
Scotland
ok, thanks for that. So delivery time is pretty short then too?
The postage time from Canada is about 7-10 days if the sender just uses Canada Post (their Royal Mail equivilant).
Everything I had from Jean has easily been within that, often a lot quicker but he posts straight away.
Alan (14point7) doesn't seem to be quite so diligent.
As I previously mentioned I had one bad experience in the past (and someone else on here, I think Jimster, too) but that was a long time ago.
My most recent purchase was just under two weeks simply because of late dispatch.
I'd suggest you put your expectations at two weeks.
But if you are patient, I'm sure it will be worth it.
nky_84
Member #: 9213
Scotland
so, Lambda controller arrived today and ive just discovered that the sensor i bought ages ago is an LSU 4.0 and the controller has a LSU4.2 plug....
Any know if these are inter changeable or not? Alternatively, can i get a lsu4.2plug from somewhere(not sure if scrappies will have these) and convert it that way? Is there any actual differences with the sensors or is it just the plug?
I will probably purchase a new lsu4.2 plug at a later date, but wanted to get this up and running by the weekend and want to avoid more waiting for postage etc
You can definitely by the plugs
Or just buy a new sensor
As to whether the sensor is compatible, best to email Toalan/14.7 and ask him.
4.2's are readily available in the UK for under £60 via egay etc.
But the 4.2 sensor is OEM fitment to thousands of VW group cars, so yes plugs may be available second hand.
Edited by stevieturbo on 22nd Apr, 2014.
Do NOT swap the plug.....
First point is the plugs on the 4.0, 4.2 and 4.9 series contain a lazer etched calibration resistor, etched to a value specific to the sensor they are attached to. Some controllers rely on this for accurate lambda readings. Others use "free air" calibration but I know that Alan much prefers the factory (lazer resistor) calibration so I'm not sure if the Spartan allows for free air calibration. Even if it does, it won't be as accurate as the factory calibration.
Secondly, some controllers work the three different series in a different way. Read up on the TechEdge site if you want a detailed description why/how (TechEdge give a lot more technical details than most).
Thirdly Alan's website says the spartan is for a 4.2 sensor. I'm sure that if it was compatible with the earlier ones, he would have said (and given that plug option).
But as Stevie says, you could allways ask him.
I'm only using 4.2s with my 14point7 SLC modules and I know they work.
EDIT - typos plus a bit added.
Edited by Rod S on 22nd Apr, 2014.
nky_84
Member #: 9213
Scotland
@stevie - Yes, i've sent an email to Alan, but i thought i'd check on here too, while i wait for a response.
I've got an audi S3 as my daily, which looks like it has the same plug. do you know if these are truly wideband? i could perhaps use this to get me running for the wknd.
@rod- i've just been reading the techedge site and noticed the section about resistors and calibration of controllers for swapping between 4.0 and 4.2 so probably best avoiding cutting wires!
evolotion
Member #: 83
Glasgow, Scotland
the sensor in the s3 is a wideband sensor and is the sensor used with my innovate controller. presume as the plug is the same itll work with yours, but your gamble :)
Denis O'Brien.
The reason widebands are so cheap today, is because of that sensor on your Audi and millions of other VAG group cars.
That has made them cheap.
nky_84
Member #: 9213
Scotland
Alan replied. Controllers are not compatible with 4.0 sensors. Hopefully this thread will prevent someone else making the same mistake!
Good (in a bad kind of way). I didn't think the 4.0 would work.
But, as Stevie says, the 4.2s are dead easy to find now.
And it's probably down to the buying power of VAG - the plugs (controller end) are mostly allways quoted by the VAG part number.
