| Home > General Chat > k1200RS cam timing 180 degrees out? | |||||||
![]() 218 Posts Member #: 9213 Senior Member Scotland |
12th Apr, 2014 at 06:41:55pm
Hi guys,
12th Apr, 2014 at 07:03:25pm
what kind of cam sensor you using? turbo 16v k-series 11.9@118.9 :)
12th Apr, 2014 at 07:05:23pm
also if your theory is correct you could swap injector wiring to 1&4 and 2&3. to prove a point. turbo 16v k-series 11.9@118.9 :)
12th Apr, 2014 at 07:44:03pm
2.4mm overlap doesnt sound right for the 16v RS cams, but it shouldn't make that much difference.
12th Apr, 2014 at 10:12:19pm
Check your firing order, the k head is different to the a series.
13th Apr, 2014 at 08:46:06am
Firing order doesn't matter with wasted spark, same cylinders are paired. On 26th Oct, 2004 TurboDave16v said:
13th Apr, 2014 at 02:23:15pm
Not running a cam sensor.
13th Apr, 2014 at 04:26:21pm
Without a cam sensor it can't be truely sequential so I guess, as Colin says, just batch.
Edited by Rod S on 13th Apr, 2014. Schrödinger's cat - so which one am I ??? |
13th Apr, 2014 at 04:40:15pm
I'm guessing this is on the base maps from SC which should be close but safe.. as long as your base timing is correct.
13th Apr, 2014 at 05:33:18pm
To give a bit of background. The car ran faultlessly for 2 seasons in N/A form. It was setup with the 2.4mm cam timing and an SC basemap, then was fine tuned on an RR where it gave 130BHP, which is in line with spec.
13th Apr, 2014 at 05:38:01pm
13th Apr, 2014 at 05:43:11pm
yes, thats one of the only other changes from before. I've changed from a basic temp sensor to a combined MAP and temp sensor bolted to the plenum. The temp and pressure readings on the laptop seemed pretty accurate |
13th Apr, 2014 at 06:12:04pm
TBH without a wideband you are flying blind.
13th Apr, 2014 at 06:38:57pm
On 12th Apr, 2014 Sprocket said:
Only Vems can run full sequencial without cam sync, but then depending on the engine, can suffer noticable running differences since you either inject on the induction stroke, or on the combustion stroke depending on where the ECU syncs up with the crank trigger. I'm sorry but that's not a feature, that's a bug. Having your engine run with the wrong tune 50% of the time is not a feature. |
13th Apr, 2014 at 06:55:42pm
Lets keep this on topic... On 11th Feb, 2015 robert said:
13th Apr, 2014 at 07:16:47pm
On 13th Apr, 2014 apbellamy said:
Lets keep this on topic... I thought it was until Colin said he has an ECU that can run fully sequential without a phase (cam) sensor. Impressive.... But, back to the real point, I would still think the base map is wrong in this case - unless physical things like the cam timing or ignition timing are also wrong - but without a wideband or any other measurements, I repeat my comment - flying blind which could end up in tears. Schrödinger's cat - so which one am I ??? |
13th Apr, 2014 at 07:26:13pm
Bugs aside.
13th Apr, 2014 at 07:28:48pm
On 13th Apr, 2014 Rod S said:
Does the load table (are whatever it is in the Typhoon software) actually show plus 100% VE ? The SC ECU systems use pulse width values much like DTA On 26th Oct, 2004 TurboDave16v said:
13th Apr, 2014 at 07:34:47pm
I might be flying blind from an AFR perspective, but ive been running the old map (verified AFR on the RR) and ecu config with the boost pipe disconnected. so its effectively NA with perhaps a bit more restriction on the exhaust side than it had before. Other changes are the compression is down slightly via the dished pistons and ive used a combined MAP and temp sensor instead of just temp. Other than that, its just been pulled to bits and put back together again, as far as i can tell... |
13th Apr, 2014 at 07:45:40pm
On 13th Apr, 2014 nky_84 said:
I might be flying blind from an AFR perspective, but ive been running the old map (verified AFR on the RR) and ecu config with the boost pipe disconnected. so its effectively NA with perhaps a bit more restriction on the exhaust side than it had before. Other changes are the compression is down slightly via the dished pistons and ive used a combined MAP and temp sensor instead of just temp. Other than that, its just been pulled to bits and put back together again, as far as i can tell... If you mean you physically have no boost - you say boost pipe disconnected - but have installed SC's base map for boost, the lower (below boost) values may well be wrong. Have you tried running with your previous map for no boost ? Also, do your MAP an IAT values look sensible when running ? EDIT - no you say you've tried the old map, I thought earlier you said you were using the base map for boost, sorry. Edited by Rod S on 13th Apr, 2014. Schrödinger's cat - so which one am I ??? |
13th Apr, 2014 at 07:51:38pm
Yeah, thats what was trying to explain in the previous post. The turbo is making boost, but ive disconnected the pipe ruining from intercooler to plenum, so its just N/A on the intake side and i'm running the N/A map from last year. MAP and IAT values looked fine yeah |
16th Apr, 2014 at 08:35:15pm
so, whipped the turbo and manifold off tonight and put the old exhaust manifold back on and it started well and revved very nicely!
