Home > Help Needed / General Tech Chat > timing backfire
ian o b
Member #: 9512
Hi all. Just looking for some ideas on what might be stopping my mini from starting
Its a standard 1275 bar comp plate (temporary till I get it started)
M45 supercharer fitted with omex 500 to run it.
Have all set up but it wont start
It will turn and turn then pop and bang so the timing is way out?
Checked it,
had vernier adj set on but put on standard thinking it was the problem,
No luck,
I probly overlooked something any suggestions welcome
Thanks
There is a list of stuff you could check but what I would do is check the firing order is correct and swing the dizzy while its turning over 10 second job if it doesnt fire try it again with more fuel
tadge44
Member #: 2500
Buckinghamshire
Timed on the exhaust stroke ?.
Are your leads 180deg out? And the firing order maybe as well? It should be 1342
