| Home > Help Needed / General Tech Chat > Braking problems | |||||||
![]() 4 Posts Member #: 10824 Junior Member |
21st Apr, 2014 at 10:52:43am
Good morning!
21st Apr, 2014 at 11:27:01am
If the pedal is always soft that would indicate air in the system, carefully check around all brake line joints, whilst getting somebody to press hard on the pedal, you might find a tiny weep of fluid coming from a joint, failing that take off the calipers and hold them so that the bleed nipple is at the absolute top and try again On 26th Jan, 2012 Tom Fenton said:
21st Apr, 2014 at 11:45:17am
On 21st Apr, 2014 Carlzilla said:
If the pedal is always soft that would indicate air in the system, carefully check around all brake line joints, whilst getting somebody to press hard on the pedal, you might find a tiny weep of fluid coming from a joint, failing that take off the calipers and hold them so that the bleed nipple is at the absolute top and try again Many thanks! The pedal is not always soft, that's the problem. We have bleed lots of times and with different methods and the problem is still here. There are also no weeps. Sometimes soft, sometimes hard. Not when cold or hot. It seems random. |
21st Apr, 2014 at 12:56:56pm
I would say
21st Apr, 2014 at 01:50:23pm
On 21st Apr, 2014 Joe C said:
I would say strip and check the rear brakes, look for anything that might be sticking, and as a result puting the pedal at a different place in its stroke and changing the leverage so it feel's harder. Also check the front wheel bearings and drive flanges for play, I have had the cheel bearing nut work loose so the disk can float about, push the pads back and put the pedal at the wrong point in the stroke. bleed and re bleed, a tuiny bubble in the caliper can heat up expand and make the pedal soft, then cool be ok etc. It is worth proping the pedal down overninght with a peice of wood between the steering wheel and pedal. it seems this will force air past the seals. Thank you very much! New things to look at
21st Apr, 2014 at 07:39:00pm
I agree, rear pistons sticking is the most likely cause.
