Home > Help Needed / General Tech Chat > Inlet manifold
rattydriver
Member #: 10808
leicester
Question... can I use a performance water heated alloy inlet manifold with a turbo set up or do I need to use the standard turbo one..????.
Either will be fine
You'll find it difficult to fit most NA inlets when using the Metro Turbo exhaust manifold though, due to clearance.
Phil.
Rammie2000
Member #: 10190
belgium
Sorry to hack this tread but maybe its better than starting a new topic for just one question.
I have 2 inlets to chose from for my turbo build. One is on the mock up engine anis an easy one to install. The other is a minispares one. As i can remember a pain in the as to instal but looks like a better item to me.
Edited by Rammie2000 on 9th Jun, 2014.
Rammie2000
Member #: 10190
belgium
this is the one on the mock up
Rammie2000
Member #: 10190
belgium
the minispares one.
Personally the minispares one gets my vote.
