| Home > General Chat > 2 reasons to read this months miniworld | |||||||
2nd Aug, 2005 at 09:54:40pm
1) AlexF |
169 Posts Member #: 409 Advanced Member Bristol |
2nd Aug, 2005 at 10:33:49pm
I have seen it - nice car! Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
2nd Aug, 2005 at 11:33:16pm
yea i saw that, seems dodgy rollers look at the spec lol |
6th Aug, 2005 at 11:52:49pm
7th Aug, 2005 at 08:52:12pm
Care to explain Vegard?!
AlexF |
![]() 88 Posts Member #: 639 Member. 13 from stoke |
8th Aug, 2005 at 08:46:47pm
Ace cover mini I'm likin that custom pic of it aswell
Edited by Super Adam on 8th Aug, 2005. visit http://www.adampoole.net !!!
10th Aug, 2005 at 03:48:27pm
up for Vegard's comments...
AlexF |
11th Aug, 2005 at 01:18:13pm
On 02/08/2005 21:54:40 AlexF2003 said:
Theres a mini on the RR shoot out that made 170 bhp (bananas). Alex The matt lamb one made 170 nanars then a car with exactly the same tech spec got 130 nanars! whats going on? visit http://www.adampoole.net !!!
11th Aug, 2005 at 01:57:17pm
Matt's car is now my car :0)
AlexF |
11th Aug, 2005 at 02:09:44pm
Its your'e car! visit http://www.adampoole.net !!!
11th Aug, 2005 at 02:17:13pm
It was a few months back... I brought it on the day of that RR!
AlexF |
11th Aug, 2005 at 05:29:34pm
On 10/08/2005 15:48:27 AlexF2003 said:
up for Vegard's comments... alex First of all, it doesn't mention any of the REALLY important stuff. Laygear clearance, and bearings, nor the problem of the small idler bearing inside the first motion shaft. These are the most important when rebuilding the box. Second, picture 11: quote:" most rod boxes require sealant rather than a gasket" BOLLOCKS! This must be the most boxes in possibly 1993, not most rod boxes. Most boxes use GASKETS! Thirdly, picture 19: quote:" Consider a niminal 0.003 inch gap to be the minimum to give a good service life. This must be good service life for the next 24miles. 0.003 is SERIOUSLY little. I usually aim for 0.040 to be the least gap. Fourthly: Why can't the mainshaft bearing be reused? It's the biggest and most decent bering in the box. The article doesn't mention any of the other bearings that need replacing. This including the idler... Strange. Finally, checking the idler clearance without fitting the transmission housing to the box with the correct gasket is useless. Gaskets are not of consistant thickness. They wary quite a lot. This means one have to take 10 measures of the gasket before settling what to use. Also,all the gearboxes are not of the same "thickness" either. Has anyone one here ever had trouble with weak selector springs in the syncro hub? I've never had any trouble with these. On 13th Jul, 2012 Ben H said:
11th Aug, 2005 at 06:21:16pm
Re the comments - Every A+ box I've seen has RTV rather than gaskets...
Edited by turbodave16v on 11th Aug, 2005. On 17th Nov, 2014 Tom Fenton said:
11th Aug, 2005 at 10:57:21pm
All 12 of the boxes I have use RTV.... not seen gaskets at all to be honest.
AlexF |
11th Aug, 2005 at 11:32:45pm
I've only worked on three or four A+ boxes, and all of them has gaskets. We've got to remember that there was rod boxes before A+ as well.
12th Aug, 2005 at 01:21:14pm
So you've seen broken weak springs in the many A+ gearboxes you've rebuilt Alex?
12th Aug, 2005 at 05:24:26pm
seen a fair few really soft ones... 1st give away is the dull clack of the hub, rather than a nice sharp click.
AlexF |
