| Home > Help Needed / General Tech Chat > Oil thermostat | |||||||
2nd Aug, 2005 at 10:33:57pm
Im currently looking for an oil thermostat, but they all seem to have 'push on' fittings for rubber hoses... "Turbo's make torque, and torque makes fun"
2nd Aug, 2005 at 11:14:05pm
I think they are 5/8 UNF if that helps "Turbo's make torque, and torque makes fun"
5th Aug, 2005 at 06:38:12pm
No sure about the thermostat, but my temp sensor's in the sump.
9th Aug, 2005 at 11:10:32pm
The thing about these thermostats is that they open too early. The open at 70 degrees, and should relly not open until 100 or so. Still beats NOT having one, but the plumbing is horrendous. I did have one, NEVER again. On 13th Jul, 2012 Ben H said:
10th Aug, 2005 at 09:01:46am
I'd go with the metro water to oil cooler, they warm your oil up when cold! On 28th Aug, 2011 Kean said:
10th Aug, 2005 at 09:06:51am
And still keep oil too cold when working....... On 13th Jul, 2012 Ben H said:
10th Aug, 2005 at 06:12:08pm
sounds a good plan, but im fitting a front rad, guess I could put the oil/water heat exchange on the remote filter block, Ill have a butchers when Im next down the garage, see if they are compatable. "Turbo's make torque, and torque makes fun"
263 Posts Member #: 115 Senior Member Austria, near Vienna |
10th Aug, 2005 at 08:25:18pm
I bought an upgrage kit from Mocal -Aeroquip which replaced the 70° stat wit an 92° stat.
Bimmer Twinky headed and turboed A-Series:
10th Aug, 2005 at 10:56:55pm
turbo harry, where abouts did you get that from? straight from mocal? "Turbo's make torque, and torque makes fun"
10th Aug, 2005 at 11:20:03pm
http://www.thinkauto.com/index.htm
11th Aug, 2005 at 09:00:00am
... to cold when working,
11th Aug, 2005 at 09:17:06am
I used to run a metro type oil-water cooler. I found that it used to actually warm the oil up more quickly than normal from a cold start.
11th Aug, 2005 at 10:18:57am
thats about what i expected,
11th Aug, 2005 at 10:31:55am
yeah, tbh im not too font of those metro water/oil coolers, thats why id like a thermostat for this 10 row air/oil cooler. "Turbo's make torque, and torque makes fun"
11th Aug, 2005 at 11:54:32pm
ive got one from avonbar that fits inbetween oil filter and housing then has 2 pipes with srew on conections (think same thread as oil cooler) but the pipes have to come off forwards so you might struggle in a roundnose.
12th Aug, 2005 at 10:24:38am
cheers carl, thing is im running a remote filter so would like to keep the plumbing as straight forward as possibly.
12th Aug, 2005 at 09:24:31pm
Found the invoice: yes, it was from thinkauto; called "Thermo element 92o 2580; product code WS92.
12th Aug, 2005 at 11:54:46pm
cheers, ordered their catalogue today. "Turbo's make torque, and torque makes fun"
13th Aug, 2005 at 04:18:00pm
Don't know if this is in the cat - my invoice says "made to special order" so better give them a call. Bimmer Twinky headed and turboed A-Series:
13th Aug, 2005 at 05:04:20pm
ah, will do. Cheers Harry "Turbo's make torque, and torque makes fun"
9th Feb, 2006 at 11:01:43am
Felt too rich today so plumped for this:
29th Mar, 2006 at 11:04:51am
On 12/08/2005 21:24:31 TurboHarry said:
Found the invoice: yes, it was from thinkauto; called "Thermo element 92o 2580; product code WS92. Hope this helps! Harry only £3.58 too bargain! "Turbo's make torque, and torque makes fun"
