Home > General Chat > Ali flanged grommets - where from?
adcyork
Member #: 6807
York
Does anybody know where I can get some of these rather smart grommets from?
RS I think do them, but be warned they are very expensive.
adcyork
Member #: 6807
York
Do you know what they're called off hand? RS has a very fussy search engine
enne
Member #: 9827
Germany
try Car Builder Solutions.
slater
Member #: 1291
Suffolk / Birmingham
Think Automotive do them
http://www.demon-tweeks.co.uk/motorsport/h...l-grommet-seals
jamiestevenbell
Member #: 9941
Derby
If deamond tweeks do them check out jjc race and rally
They are called seals-it grommets I was given two a long time ago , I have found that the rubber splits over time. As both of mine has now so I have glued the one in there now.
adcyork
Member #: 6807
York
wow, at £16 minimum ill can that idea for the time being. Does anyone know a good place to buy rubber boots/gators?
I'm looking for something suitable to use as a gator for the aperture in the floor for the internal mounted gear linkage
Have a trip down to the local scrappers, the ones that let you wander,
most if not all modern cars have something similar where the loom passes through the bulk head mine is off a 1995 honda and the rubber is good as new much better than the modern shit thetic rubber
