| Home > Help Needed / General Tech Chat > Hesitant when on boost/under load. | |||||||
![]() 171 Posts Member #: 9928 Advanced Member Hartley, Kent |
1st May, 2014 at 02:33:35pm
as above, standard metro turbo setup becoming very hesitant whilst boost is building up, if you keep your foot down it will begin to misfire and sometimes even pop (what i believe to be back through the carb). I have not changed anything when this originally happened, it just started doing it out of the blue. But then! sometimes its completely fine and fucks off into the sunset..
Low boosting for now. |
1st May, 2014 at 03:03:32pm
Poping back through the carb is almost certainly due to being lean
Yes i moved to the darkside |
1st May, 2014 at 03:06:04pm
hmm i did try this yesterday, made a slight difference but nothing noticable, i mean it starts hesitating almost as soon as you hear the turbo spooling, obviously the mixture screw wont make any difference will it?
1st May, 2014 at 04:25:19pm
Tryed the 'T' peice trick? Search it on here
Edited by Brett on 1st May, 2014. Yes i moved to the darkside |
1st May, 2014 at 04:38:12pm
using the T piece trick still as stated in original post above.
1st May, 2014 at 05:24:23pm
Go for the part throttle pipe. In the 13's at last!.. Just |
12th May, 2014 at 02:22:05pm
Checked part throttle pipe nothing wrong there, taken out the intercooler to help narrow down the amount of pipework that could be faulty, still having the same symptoms!
24th May, 2014 at 11:25:26am
Did you change the part throttle pipe or just inspect it? It can develop cracks/splits that aren't apparent by just looking at, and as it is just a short length of fuel hose it may as well be replaced to eliminate it as a potential source of the problem. |
24th May, 2014 at 11:41:20am
replaced it, blanked it no difference, however i did make some progress, took out all the old dashpot oil and refilled it with halfrauds 20w/50 and it runs a hell of alot better but still not quite 100% Low boosting for now. |
