| Home > General Chat > Gear Set ratio calculations? | |||||||
7th May, 2014 at 04:55:45am
Right so i have a bunch of boxes and was wondring what ther ratios are in each gear so counted up the teath and still coundent work out how its divided or what ever to give something that looks correct..
7th May, 2014 at 06:48:24am
Use a satnav to double check your cars speedo, they're pretty accurate these days. On 26th Jan, 2012 Tom Fenton said:
7th May, 2014 at 08:17:45am
Your maths is essentially correct but if you want to do the comparison, just do it in 4th gear because then (as your drop gears are 1:1) you only need to know the FD ratio.
6th Sep, 2014 at 08:42:34am
might give that a go rod i know a nice road with a slight decline saves me pushing
