| Home > Help Needed / General Tech Chat > Fuel pressure regulator | |||||||
![]() 537 Posts Member #: 8926 Post Whore Sheffield |
13th May, 2014 at 06:49:50pm
Hi guys
13th May, 2014 at 08:12:35pm
If the pressure wont drop either the reg's buggered or there is a restriction in your fuel return {ie, to small or blocked}
13th May, 2014 at 08:31:15pm
8mm return Phil.
13th May, 2014 at 09:49:50pm
Took your advice on the return being blocked and you are correct. Must have been a air lock or a small bit of dirt, thanks Phil! |
13th May, 2014 at 10:23:49pm
No worries, glad you sorted it mate.
13th May, 2014 at 10:23:51pm
13th May, 2014 at 10:23:54pm
14th May, 2014 at 12:20:12am
Must have been 3rd time lucky Yes i moved to the darkside |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
14th May, 2014 at 06:31:45am
Its ALIVE What the mind can conceive the mini can achieve
14th May, 2014 at 06:31:46am
Double post Edited by lee.pb on 14th May, 2014. What the mind can conceive the mini can achieve
14th May, 2014 at 09:30:38am
haha mega double posts in here!
14th May, 2014 at 10:26:50am
On 14th May, 2014 Nick warwick said:
haha mega double posts in here! Its on the RR today mate. Took it out last night and it runs nice but goes a little lean around 60-70 if you floor it. What the mind can conceive the mini can achieve
14th May, 2014 at 10:47:02am
Only 7psi at the moment mate.
![]() 330 Posts Member #: 9628 Senior Member |
14th May, 2014 at 11:18:26am
GOOD LUCK!!!! |
