| Home > Help Needed / General Tech Chat > AFR sensor | |||||||
![]() 330 Posts Member #: 9628 Senior Member |
15th May, 2014 at 12:06:09pm
where should it be fitted on the downpipe?
42 Posts Member #: 9575 Member Nr a shithole (Wolverhampton) |
15th May, 2014 at 12:13:27pm
mine's half way down the downpipe. Not saying that's right but it does it's job |
![]() 218 Posts Member #: 9213 Senior Member Scotland |
15th May, 2014 at 12:44:44pm
Instructions for mine are detailed here: http://cdn.shopify.com/s/files/1/0189/1312...Manual.pdf?2057
15th May, 2014 at 12:58:51pm
Read the sellers instructions - they all vary because of the way the different contollers deal with the cell (sensor) temperature.
15th May, 2014 at 01:32:02pm
This is from the latest 14point7 manual
15th May, 2014 at 03:44:17pm
My sensor is about 6" after the turbo, like lots of others on here nd no problems so far.
15th May, 2014 at 04:20:30pm
A lot of factory fitted sensors will be close to the turbos either because (a) they are narrowband sensors where the cell temperature doesn't have to be closely controlled for accuracy or, (b) they ignore Bosch to gain themselves repair costs later in life (yes, that's me being cynical but it happens, cars are designed to last their warranty period, then reap in the funds from repair costs at the main agents).
Edited by Rod S on 15th May, 2014. Schrödinger's cat - so which one am I ??? |
15th May, 2014 at 05:06:33pm
So I am living on the edge again then Rod !!!! |
15th May, 2014 at 05:11:47pm
David, I doubt it....
15th May, 2014 at 08:38:16pm
That is rather what I meant, especially given the grief I dole out to what is a collection of second hand bits screwed together by an amateur.
