| Home > Help Needed / General Tech Chat > Buggered 4 pot caliper | |||||||
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
17th May, 2014 at 05:17:35pm
I'm out of ideas now and I'm praying for help as I've got a brake piston refusing to budge from the caliper. None of them would come out under brake pressure so put the caliper on the workbench and put my air line in and 3 blew out but the 4th refuses to move. Heat hasnt worked. neither has a good WD40 soaking so any miracle ideas out there? Pleeeeease as I'm not going to spend money on another caliper that might have the same problem Masturbation is not a crime its a hobby |
17th May, 2014 at 05:20:59pm
Grease gun should move it, but you'll have to refit the other pistons and wedge them in place. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
614 Posts Member #: 2153 Post Whore kings langley |
17th May, 2014 at 05:26:50pm
Clamp the caliper tightly in a soft jawed vice, then use two pry bars or crow bars with the bends opposing each other it doesn't matter if you mark the inside of the piston as it never comes in contact with anything. Squeeze the bars together and wiggle and pull it out just dont twat yourself in the face when it comes free Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
976 Posts Member #: 3228 Post Whore North of the Netherlands |
17th May, 2014 at 07:08:38pm
I had exactly the same problem with my 4-pots.
Dazed and Confused.... |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
19th May, 2014 at 10:22:05am
I have a set of Metro 4-pots that came off a working car last year if you need them. Metric is for people who can't do fractions. |
25 Posts Member #: 3824 Member Zeebrugge belguim |
19th May, 2014 at 11:29:20am
ive got a rebuild set laying around gathering dust |
21st May, 2014 at 07:49:46pm
How much do u want for them Alex? The pistons determined its staying in the caliper Masturbation is not a crime its a hobby |
21st May, 2014 at 08:24:43pm
No idea at all what they are worth.
21st May, 2014 at 08:49:29pm
I've pm'd u alex Masturbation is not a crime its a hobby |
21st May, 2014 at 11:10:24pm
like the grease gun idea |
144 Posts Member #: 10557 Advanced Member |
22nd May, 2014 at 06:32:59am
grease gun method is the only sensible way to put enough pressure on it in a controlled way..... use it all the time on the older land rovers with piston surface areas twice the size and hasn't failed yet....but then again there is always tomorrow.
Double-Blind experiment, N:
22nd May, 2014 at 09:14:03am
I tried the grease gun method and the piston still wouldn't shift. It's well and truly rusted in. Masturbation is not a crime its a hobby |
