| Home > Help Needed / General Tech Chat > clutch judder | |||||||
![]() 323 Posts Member #: 41 Senior Member |
13th Jan, 2004 at 08:56:15pm
moved the car in and out of the garage on the weekend, out drive is quite steep so i thought it would be a good test for the clutch and everything else, started to reverse out and the was a noticeable judder, as i slipped the clutch and held it on the bite be became slightly worse, does anyone think this is normal for a new clucth to do for the first time until it beds in?? its just an orange diaphram, ap racing plate, lightened steel flywheel etc. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
13th Jan, 2004 at 09:43:29pm
it may not sound very relivent, but what do you have in the way of engine mounts / steadys? On 15th May, 2009 TurboDave said:
14th Jan, 2004 at 01:29:05pm
ive got the standard engine mount which has had new uprated bushes fitted, ive also got the two gearbox-subframe steadies, so the engine isnt going anywhere, ive got the front off so i could see the engine as i reversing out and it was hardly moving. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
14th Jan, 2004 at 04:08:11pm
what type of clutch is it?
AlexF |
15th Jan, 2004 at 10:23:56am
pre verto A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
15th Jan, 2004 at 11:01:42am
it might just be the clutch... pre-verto is slightly juddery (hence rover changing the design) and as yours is orange & race plate it might be that...
AlexF |
15th Jan, 2004 at 12:19:21pm
cheers for those pointers alex, i wasnt sure not having a race clutch before if they are like that or whether its the symptons of me doing something wrong when putting it together lol cheers. take it for a drive this weekend A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
