| Home > Help Needed / General Tech Chat > GT17 water return. | |||||||
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
23rd May, 2014 at 08:52:29am
Hi
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
23rd May, 2014 at 09:29:08am
Are you still running a internal heater ?
23rd May, 2014 at 09:57:56am
No heater fitted... Engine is all built so don't want to be drilling and tapping the block etc. On 25th Sep, 2009 mini13 said:
23rd May, 2014 at 10:57:06am
If you put it into a sandwich plate, make sure you put the thermostat below the sandwich plate, other wise you will just cycle hot water round the engine. On 11th Feb, 2015 robert said:
23rd May, 2014 at 11:32:05am
Thanks andy, that was my concern about the position of the thermostat and circulation. I've just ordered a dsn sandwich plate and thermostat housing :) On 25th Sep, 2009 mini13 said:
23rd May, 2014 at 01:08:12pm
If you take the feed from the No4 end of the head you will be taking it from the hottest possible location and a low pressure location.
23rd May, 2014 at 01:31:04pm
So Rod am i right in thinking that taking the feed off the rear off the block and returning the water back to the top of the radiator is probably the best for the GT17 or any water colled turbo.
On 23rd May, 2014 Rod S said:
If you take the feed from the No4 end of the head you will be taking it from the hottest possible location and a low pressure location. It simply won't circulate, apart from when the thermostat is closed, when it will circulate backwards. If you actually want to cool the turbo bearings, the feed must be "cold" and (as far as is possible) from below the turbo, ie, the bottom of the block, where the pump pressur e is highest, and the return into something high up and "hot", ie, the pipe into the top of the radiator. The flow will mostly be "pumped" when the engine is running so you need to replicate the feed being just after the pump (and before the engine has heated it) and the return just before radiator (which is just before the pump so will "suck" and cool it). Once the engine is shut down, the heights become even more important as you will rely on thermo-syphon to continue to cool the bearings without the pump. What the mind can conceive the mini can achieve
23rd May, 2014 at 02:58:54pm
On 23rd May, 2014 lee.pb said:
So Rod am i right in thinking that taking the feed off the rear off the block and returning the water back to the top of the radiator is probably the best for the GT17 or any water colled turbo. Absolutely yes. Rear of the block near to the pump outlet is coldest and highest pressure. Top of the radiator is lower pressure and where the heated water goes from the engine anyway. Putting the flow into the heater circuit is a compromise, ie, you are trying to cool it with hot water, but at least the water will flow in the right direction with the engine running. The more important point is thermo-syphon once the engine is shut down. If you want that to work once you have lost pump pressure, the inlet has to be low and cold and the return high and hot. Schrödinger's cat - so which one am I ??? |
23rd May, 2014 at 03:31:52pm
So the connection on to the radiator has to be lower than the water in the top of the radiator... if that makes sense. What the mind can conceive the mini can achieve
23rd May, 2014 at 04:04:52pm
Thanks for the explanation, it's helped my understanding of the cooling system. As I said before, taking the water feed from the back of the block as you said isn't an option as ive just had the engine built, so can't be drilling and tapping into it now. I know it's not a solution, but if I ran an auxiliary rad between the head take off and the turbo, would that help to cool the coolant before its passed through the turbo? On 25th Sep, 2009 mini13 said:
