| Home > Help Needed / General Tech Chat > Getting pissed off with one side of Shauna's handbrake not working. | |||||||
25th May, 2014 at 12:43:50pm
Never in my life have I had such a problem getting a handbrake to work properly. The worst part of it is that the passenger side actually works! So since having the car she's had new drums, new shoes, new cables, the adjusters were working properly and adjusted up properly and I've just fitted a new handbrake lever on the side that doesnt work properly. The passenger side works lovely. What else can I do to make this work as I'm really at wits end with it, the adjuster was wound up more to get the handbrake on the drivers side to actually do something but now I've taken the drum off again it's prematurely worn the shoes and there was a load of dust in there. Even when it does 'something' you can still grab the wheel and turn it easily. If you pull on the cable on the radius arm towards you it starts to actually pull up properly which made me think it may have been the lever. But the amount you have to pull it to make it lock up is probably nearly an inch Edited by Carlzilla on 25th May, 2014. On 26th Jan, 2012 Tom Fenton said:
25th May, 2014 at 01:24:50pm
quadrants getting stuck
25th May, 2014 at 02:35:22pm
Quadrants move freely, rear wheel bearing is fine, shoes definitely the right way round and the rear cylinder does work when you press the brakes. I'm sure it's got to be something in the setup I've overlooked or something. New cables too. On 26th Jan, 2012 Tom Fenton said:
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
25th May, 2014 at 02:48:54pm
Is it twin cables or a single? If it's a single, get some grease on the the link where the handbrake short cable meets the rear cable. Make sure the grease gets in right where the cable runs against the link on the long cable.
Edited by Carl S on 25th May, 2014. |
25th May, 2014 at 03:32:41pm
Single cable mate, probably haven't got enough grease in there. I'll have to get under with the grease gun and grease the crap out of it. On 26th Jan, 2012 Tom Fenton said:
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
25th May, 2014 at 06:29:27pm
has the lever arm coming out of the back plate ever been changed? There are 2 different sizes available so if you've got a mix 1 side will never work properly Masturbation is not a crime its a hobby |
26th May, 2014 at 03:04:34pm
I've issues with this in the past but generally its been with the twin cables.
26th May, 2014 at 03:28:50pm
pull the hand brake on, and get underneath and check the quadrant isnt hitting the radius arm,
142 Posts Member #: 10808 Advanced Member leicester |
29th May, 2014 at 09:26:23pm
I had the same problem, found the quadrant was hitting preventing full travel so I cut a bit off, now works perfect.. ps I had fitted new cables aswell
