| Home > Help Needed / General Tech Chat > dry decking BMW k1100 conversion | |||||||
37 Posts Member #: 5037 Member |
27th May, 2014 at 10:57:59am
Is it possible to just dry deck the block ? and leave head alone , ie no filling holes / welding / distorting ?
27th May, 2014 at 11:09:22am
I guess it would be, but why bother doing half a job? On 15th May, 2009 TurboDave said:
27th May, 2014 at 11:11:30am
my dad is just worried about head distortion i think .. as it looks alike allot of welding needed.
Edited by 16vmini on 27th May, 2014. |
27th May, 2014 at 11:56:36am
the head will be fine. you need to preheat the whole head before welding it though otherwise you can get hair line cracks forming as it cools unevenley. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th May, 2014 at 11:58:53am
so .. what are the down sides to not blocking head , assume still prone to head gasket failure still ? |
27th May, 2014 at 02:09:16pm
it kind defeats the object of dry decking, as you are still relying on the head gasket to seal the water and oil from the cylinders. with a standard dry deck, any head gasket failure will still prevent water/oil contamination. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th May, 2014 at 02:26:39pm
fair point , and all noted.
27th May, 2014 at 06:21:46pm
Thing is you need to weld it anyway to do the conversion! Once its hot it takes 10 mins to do the full job.. |
27th May, 2014 at 09:42:03pm
Die grind the edges of the water ways, pre-heat, build one layer of weld all around all the holes using 4043 filler and the appropriate balance to get a clean weld. Clean again, then weld back to back (adjust balance up) to plug the holes... I found it realllllly easy, but everything seems easy with this welder tbh (OK, everything apart from getting the rainbow welds in stainless lol)... Edited by turbodave16v on 27th May, 2014. On 17th Nov, 2014 Tom Fenton said:
27th May, 2014 at 10:23:11pm
27th May, 2014 at 11:26:51pm
Ah, yes. That's the problem. Fuckyou very much lol On 17th Nov, 2014 Tom Fenton said:
29th May, 2014 at 09:35:25am
some serious work going on here:
976 Posts Member #: 3228 Post Whore North of the Netherlands |
29th May, 2014 at 12:00:55pm
On 29th May, 2014 Jimster said:
some serious work going on here: http://www.weldingtipsandtricks.com/weldin...nder-heads.html Amazing! Those last "Before - After" pictures....!
Dazed and Confused.... |
29th May, 2014 at 07:35:59pm
some serious work going on here: http://www.weldingtipsandtricks.com/weldin...nder-heads.html im just starting out learning to tig, and this is fantastic Yes i moved to the darkside |
30th May, 2014 at 08:29:18am
took me ages to make that video On 15th May, 2009 TurboDave said:
46 Posts Member #: 9934 Member south wales |
30th May, 2014 at 08:56:22am
That's a great vid Jim..if I pop my k100 head d!own could you show me how you do it ???? |
