| Home > General Chat > Optima batteries and ctec chargers | |||||||
28th May, 2014 at 09:28:22am
Any one on here use one?
Edited by Brett on 28th May, 2014. Yes i moved to the darkside |
28th May, 2014 at 09:31:46am
and this
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
28th May, 2014 at 09:40:23am
how are you killing batteries? iv had the same one on the mini for over ten years? Done now needs redoing lol |
28th May, 2014 at 10:21:01am
un hook them through winter and never work again, the last mini battery came in side as i thought it was cold killing them and it still died, the bosch warranty came in usefull for those, the cold and snow a couple years back the killed volvo battery
111 Posts Member #: 29 Advanced Member Croydon |
28th May, 2014 at 10:44:51am
I killed several batteries over the years, until i realised that Gel/optima type batteries need a different charger.
Too many projects! |
28th May, 2014 at 12:02:10pm
In my old job (working with skylines almost constantly) we would fit these https://www.youtube.com/watch?v=jaSb-HYqh6o
28th May, 2014 at 03:51:53pm
This is what I want to hear Yes i moved to the darkside |
28th May, 2014 at 06:07:55pm
I've got one it used it yet I run a supercharger and I don't care the TB is on the wrong side.
29th May, 2014 at 07:40:38am
Ordered one anyway, ill let you know how it gets on hopefully it can sort out the optima and this other lead acid one I have Yes i moved to the darkside |
29th May, 2014 at 12:24:47pm
I use one on my battery over winter it's very good! |
30th May, 2014 at 10:47:49am
Denis you probably know then skylines seem to bequite heavy on the batterys for some daft reason any theory on why? Skylines in general seem to have a low charge voltage13.8-14v ish could this be the cause? g always just put it down to heavy parasitic draw and tiny little battery's. i mean the battery is the same size (give or take) as that used in a honda jazz, yet has to start a 2.5/.6 litre engine via ~2.5m of cabling. if a battery was good itd be fine, but you couldnt leave it sitting for months without a charger due to parasitic draw(unless it had a kill switch), and you couldnt start the car for a week solid just to run it in and out of the workshop. was a real issue for us in that respect, to the point where we would run a skyline up to temp every time we started it even if it was just getting moved out the workshop to give the battery a fighting chance (and prevent flooding on the big HP ones). Ment puttng fuel in the cars regularly but still cheaper than a battery, and saved teh hassle of pulling and cleaning sparkplugs every other day. if we knew a car would be sitting, it got a full charge, and then the battery disconnected. turbo 16v k-series 11.9@118.9 :)
30th May, 2014 at 01:20:22pm
Cheers Denis
