| Home > Help Needed / General Tech Chat > Bit of a bang. | |||||||
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
28th May, 2014 at 06:38:08pm
Ran at shakey last weekend,first time for almost a year. Made a horlicks of the burnout,got off the line,then seemed to lose drive. Much frantic pedalling and stick waggling,in the middle of which were a couple of bangs(backfires?). Rolled into the runoff area with no drive in any gear and the engine idling at 3000 rpm.
'Where does the engine go?' |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
28th May, 2014 at 06:45:51pm
oops hope you can save it Done now needs redoing lol |
28th May, 2014 at 06:46:24pm
I am sure this happened to matt woods (damper rod) that is maybe you could ask him? I have started posting on Instagram also my name on there is turbomk1golf
28th May, 2014 at 08:39:54pm
I was thinking the same thing simon |
28th May, 2014 at 09:08:12pm
Matt woods bent a con rod with a nitrous fart.
29th May, 2014 at 06:12:44pm
Thanks for this I'll talk to Matt.The blowout disc sounds a good idea.I won't know just what happened until I pull it all apart,but the plenum is black inside.Not sure of the butterfly position either as the inlet ports look clean? 'Where does the engine go?' |
24th Jun, 2014 at 07:47:44am
Ok so back running again.I refreshed the engine (bearings timing chain cam followers valve grind) replaced the clutch and skimmed the flywheel.The bang in the carb I think was caused by over revving when the clutch went,with exhaust gas igniting the fuel/NOS in the inlet.So I replaced the dashpot damper,throttle disc and seals and she idles better than before I think.Now to get some miles in before I really test it. 'Where does the engine go?' |
24th Jun, 2014 at 10:29:43am
24th Jun, 2014 at 12:02:38pm
is this back fire disc simlar to a core plug? as in a lose press fit that will take say 50 psi before it falls out
24th Jun, 2014 at 02:26:58pm
Pleased to hear that it was not more serious, Steve. |
24th Jun, 2014 at 08:36:36pm
Thanks guys,let's hope it still does it's stuff. 'Where does the engine go?' |
24th Jun, 2014 at 08:40:44pm
is it a stronger clutch steve ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
25th Jun, 2014 at 07:25:37am
No Robert,but the last one survived 4 years of abuse.The problem is to find a Ford clutch that will fit on the Midget flywheel,most are too large in diameter. If I have to go stronger I think it would need to be a slipper type. 'Where does the engine go?' |
25th Jun, 2014 at 10:53:27am
cool. was it the centre of the plate that tore out ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
25th Jun, 2014 at 06:57:35pm
No,it shed the lining completely,which filled up the bell housing! Amazing volume of the stuff,it even jammed the starter bendix.The plate was left all bald and shiny,like me. 'Where does the engine go?' |
22nd Jul, 2014 at 08:37:47am
So went back to Shakey on Sunday, got in 5 runs re-tuning the nut on the steering wheel and finished with a 12.4/110 pass which is only 0.1 off a PB.Last run I had an oil leak from the turbo feed banjo bolt coming loose.Very exciting when this got onto a rear tyre and I actually had to LIFT! Anyway easy fix and then I trundled home,very happy with the day 'Where does the engine go?' |
22nd Jul, 2014 at 08:42:42am
nice one good to hear its all sorted Done now needs redoing lol |
22nd Jul, 2014 at 12:17:26pm
nice... I run a supercharger and I don't care the TB is on the wrong side.
22nd Jul, 2014 at 03:58:38pm
excellent!
22nd Jul, 2014 at 07:22:05pm
27th May, 2015 at 11:06:07am
Haven't updated in a while.
Edited by steve1275 on 27th May, 2015. 'Where does the engine go?' |
27th May, 2015 at 02:28:34pm
12.2 good work :) If something is worth doing, it's worth doing half of. |
27th May, 2015 at 08:38:38pm
Thanks John it felt good 'Where does the engine go?' |
24th Jun, 2015 at 10:01:50am
Fitted some 50% stiffer rear springs and went back to Shakey last Sunday. Track was really good and ran 12.09/112 with 1.75 60ft. So feel I'm getting near my goal of a 5 port A series into the 11s and then driven home 'Where does the engine go?' |
24th Jun, 2015 at 10:18:49am
That's good going. That next tenth may be hard to find. On 11th Feb, 2015 robert said:
