| Home > General Chat > spark amplifiers | |||||||
31st May, 2014 at 11:51:27am
has anyone else seen the so called 'spark amplifiers' on the market?
31st May, 2014 at 11:55:56am
On a head with an open chamber shape & poor burn characteristics they're supposed to be good. If the head had a more efficient chamber shape (ala stock A-Series) the benefits are reduced.
31st May, 2014 at 12:04:08pm
31st May, 2014 at 12:28:23pm
On 31st May, 2014 apbellamy said:
Snake Oil. Not necessarily. As with most things on the market there are good and bad systems. A decent system will increase spark temperature, current and energy. As I said above if the engine already has efficient burn characteristics then a standard ignition delivering a decent spark is fine. The gains are seen on less efficient designs. Phil. |
31st May, 2014 at 12:31:29pm
A more important question is what ignition system are you currently using ?
31st May, 2014 at 04:37:14pm
currently using mj.
31st May, 2014 at 04:54:00pm
Nobody else has them fitted even under silly boost, wouldn't bother myself. Extra weight too! On 26th Jan, 2012 Tom Fenton said:
31st May, 2014 at 08:10:43pm
IMO i wouldnt bother dan if you have a good blue spark which jumps some way and blows your balls off ........lol
31st May, 2014 at 10:00:20pm
On 31st May, 2014 welshdan said:
currently using mj. no major issues, but then from what I can see this isn't designed to resolve problems. but supposedly enhance what you already have. just wondering if anyone has any experience of them on a mini Most modern systems are very powerful as they are. Unless you're at the far end of 30psi boost and exeriencing ignition problems...save your money 9.85 @ 145mph
