| Home > Help Needed / General Tech Chat > Wheel Studs - Upgraded? Or Titanium? | |||||||
105 Posts Member #: 8995 Advanced Member Poole, Dorset |
6th Jun, 2014 at 08:30:41pm
Not sure if I've just got some poor quality ones, but a few of the studs on my Mini rear hubs have stripped.
7th Jun, 2014 at 05:52:44am
Upgraded are unecessary, youve just done yours up too tight I seriously doubt it! |
7th Jun, 2014 at 08:15:29am
I've snapped hundreds over the years, sleeved nuts are the worst. Now stick to 63Nm and I've never broken another.
7th Jun, 2014 at 08:37:35am
Ive heard of cheap shitty pattern studs stripping, but good genuine ones shouldnt do this as Wil says.
264 Posts Member #: 8853 Senior Member Bristol |
7th Jun, 2014 at 10:28:01am
Ti ones will be nigh on impossible to find. They'd have to be forged which not a lot of people do and the benefit would be minimal |
7th Jun, 2014 at 10:44:10am
As long you have a decent set of wheel nuts as well you shouldn't have a problem when tightening them to 63nm.
8th Jun, 2014 at 08:10:09am
Swiftune ones are stronger, but the most important thing is to use a torque wrench as mentioned... On 13th Jul, 2012 Ben H said:
8th Jun, 2014 at 08:22:57am
Or going to the usual workshop method of 90nm is going to snap or strip them off eventually. On 26th Jan, 2012 Tom Fenton said:
8th Jun, 2014 at 05:21:53pm
On 8th Jun, 2014 Vegard said:
Swiftune ones are stronger, but the most important thing is to use a torque wrench as mentioned... Thanks for all the replies, very useful. The Swiftune ones look good, albeit a bit expensive at £7.50 or something each. I always use a torque wrench and lower torque than standard wheel nuts, so I suspect I had some sub-standard studs. |
9th Jun, 2014 at 10:03:00pm
Swiftune ones are stronger, but the most important thing is to use a torque wrench as mentioned... Thanks for all the replies, very useful. The Swiftune ones look good, albeit a bit expensive at £7.50 or something each. I always use a torque wrench and lower torque than standard wheel nuts, so I suspect I had some sub-standard studs. So what you're saying is that you're OK with cheap bolts that break then
